To obtain your registration ID "Invitation Code", please send your request to: [email protected]
If you are a registered member in MHH and not able to login or recover your account, Kindly contact [email protected]
Post Reply
  • 0 Votes - 0 Average
307 1.6 IMMO OFF ME7.4.4
06-19-2017, 07:09 AM (This post was last modified: 06-19-2017 07:11 AM by Diagi.)
Post: #1
Peugeot 307 1.6 IMMO OFF ME7.4.4
Hello,
I've strange problem with this car. Came with start problems, no start after probably disconnecting battery. This is what I do not want to comment.
ECU is matched correctly, tried it, I have a PIN also. Tried to make IMMO OFF in this ECU with success but: on IMMO off files it tells that it is 206 ECU in PP during diagnosis and tere is P0655 DTC. Aircondition is not working, thats the main problem.
Attached ori files from car, maybe someone can take a look and make IMMO off on those files. Additional there is a problem with telecoding in this ECU on those ori files.
If it doesn't succeed I want to make the ECU virgin and try to match it one more time.
Best regards
Attached File(s)
Peugeot me7.4.4.rar
File Type: .rar
Downloaded: 8 times
If this post was helpful, do not forget to press "thanks" and "reputation".
Genuine: MAGPro2 full, WinOLS, VCDS, CDIF, X-CAN, UPA-S
Find all posts by this user
Quote this message in a reply
06-19-2017, 07:18 AM
Post: #2
RE: 307 1.6 IMMO OFF ME7.4.4
Try it and Report
Pass in PM
Regards
Attached File(s)
immo off.rar
File Type: .rar
Downloaded: 3 times
06-27-2017, 04:54 AM
Post: #3
In this case we need to make IMMO off in both flash + eeprom so this solution does not work. For virginise this ECU it is enough to make only eeprom.
Anyone else with immo off or at least virgin it?
06-27-2017, 05:21 AM
Post: #4
try and report
Attached File(s)
Peugeot me7.4.4_off.zip
File Type: .zip
Downloaded: 6 times
06-27-2017, 08:46 AM
Post: #5
If the ecu is 0261206943 and you use 0261206942 immo off files, your A/C will not start for sure.
regards
If my post was helpful, please click Reputation & Thanks buttons Rauch15
Manolis Gkogkolos
Skype id: m_gogolos
[email protected]
Visit this user's website Find all posts by this user
06-27-2017, 11:19 PM
Post: #6
agv, you gave me another flash I've attached here. I can not use it becuase even if it work it will be still problem with AC or bad recognising ECU as 206 and not 307.
I need to make IMMO off or virgin exactly this ECU files I've attached, with number 0261207474. Someone?
07-04-2017, 10:26 AM
Post: #7
We can close this topic, finally having more time with this car I decided to make everything stock and original. I never leave my topics without solution so for those who will have similar problems in the future:
I noticed that the problem was not in ECU but in BSI. I find out that in BSI is the same VIN number but there is another PIN and keys are not matched, bad telecoding.
So I put back original content to ECU flash 29F400 and eeprom 95160.
Than disassembled BSI, in this case it is Valeo with MC68HC912DG128.
Than I made BSI virgin, put it into the car and make new adaptation and telecoding with PP.
Best regards
 Thanks given by: darkshiningg
Post Reply
Possibly Related Threads...
Thread: Author Replies: Views: Last Post
Audi Audi A4 B7 ME7.5 Immo off nimametal 2 83 Yesterday 10:32 PM
Last Post: nimametal
Alfa Alpha Romeo 147 ME7.3.1 butanos 0 72 08-17-2017 02:03 PM
Last Post: butanos
VW VAG IMMO OGG ME7.1.1 joe1953 1 114 08-15-2017 01:47 AM
Last Post: MK2-VRT
  Immo OFF 95040 Bosch Me7.5.10 S-tune 4 149 08-13-2017 11:12 PM
Last Post: S-tune
  Immo off peugeot 307 2.0i 2003 possible? einkaa 4 134 08-13-2017 12:40 PM
Last Post: einkaa
  ME7.x Correction / Checksums VAG ME7.1.1 MK2-VRT 7 202 08-13-2017 09:29 AM
Last Post: MK2-VRT
Porshe Porsche 911/996 ME7.8 Immo Off? limitless-remaps 2 119 08-08-2017 04:41 AM
Last Post: limitless-remaps
  OFF FAP 307 1.6 HDI EDC16C3 0281011234 KWP2000 7 153 08-06-2017 04:46 PM
Last Post: Nabil77
  VAG ME7.1 Winols Checksum MK2-VRT 12 302 08-06-2017 02:47 AM
Last Post: MK2-VRT
  need dpf off for 307 belka163 2 103 08-03-2017 07:49 AM
Last Post: Artifact
User(s) browsing this thread:
2 Guest(s)
