  • 2 Votes - 2.5 Average
407 engine fan Start late at 114°c !
01-11-2017, 03:03 AM (This post was last modified: 01-11-2017 05:07 AM by khaledauto.)
Peugeot 407 engine fan Start late at 114°c !
Hi, I need your help please,
I have a Peugeot 407 2006 year, 2.0 RFJ engine code, IAW 6LPB ECU, HW 9659580780, SW 9662982980.
The problem is the engine fan Start late at 114°c, no fault of fan in memory of ecu, there is fault of electric thermostat (P0597) but the engine without electric thermostat.
Is the problem of flash ecu?
someone have a ori file?
Thanks in advance.
Attached File(s)
407.rar
File Type: .rar
Downloaded: 3 times
01-11-2017, 05:39 AM (This post was last modified: 01-11-2017 05:40 AM by Vish.)
RE: 407 engine fan Start late at 114°c !
Have you checked configuration on engine ecu
is your first speed of fan kicking in
01-12-2017, 02:27 AM (This post was last modified: 01-12-2017 02:39 AM by khaledauto.)
Peugeot RE: 407 engine fan Start late at 114°c !
Hi
Thanks for your answer, the fan works well with the A / C and When I test the actuators, fan function normally, when it starts at 114°C starting on full speed.
There is no configuration for the fan activation in ecu.
01-12-2017, 02:48 AM
(01-11-2017 03:03 AM)khaledauto Wrote:  Hi, I need your help please,
Thanks in advance.
Hi,look the archive,like say vish check if the fan operate at fisrt velocity,if not check the
wiring diagram.I think the electric termostat don´t operate as well.
DOC REF 407.rar
File Type: .rar
Downloaded: 6 times
BeerBeer
01-12-2017, 03:36 AM
Thanks in advance.
Note:
For vehicles with a plug connection
On the thermostat housing, the following OE parts (Certus)
For the amendment:
1x 1343KZ = hose
1x 6582GW = plug connection
1x 6980A7 = holding strap
Should the error P0597 be read out
The additional cable 9678362080 must be installed.
Link is in German
http://postshop.autoteile-post.de/catalo...0,655540,7
01-12-2017, 08:07 AM
Post: #6
there is no electric thermostat and thread from ecu (pin 4H_ con 32V MR) to electric thermostat (pin 2).
I shall install a new thermostat and raccording to the ecu or
change the dump of ecu.
Attached File(s)
407 RFJ.rar
File Type: .rar
Downloaded: 2 times
01-12-2017, 10:59 PM
Post: #7
Fan begins to spin if the temp sensors reads wrong temp!
You should change both the temp sensor and the thermostat!
01-14-2017, 03:57 AM
Post: #8
first check what type of fan do you have on this car..they have few version..some with aditional controler build in fan motor ..some with aditional wire resistor and relays..looks to me that you have only ..let we say ..emergency fan blowing ..when engine ecu think something is realy wrong..so check can you start actuator test some slow speed of fan..maybe in configuration you have few options for fan types and somebody choos wrong..
its french so many MAYBE involved always...
good luck
  Peugeot 407 Webasto nilsson 1 144 03-14-2017 09:07 PM
Last Post: AlexDoerr
Peugeot Peugeot 407 2.0i IAW 6LPB Original File? khaledauto 2 182 01-18-2017 01:36 AM
Last Post: khaledauto
Peugeot need help about FAULT code peugeot 407 U1208 hafido1983 7 250 01-13-2017 12:28 PM
Last Post: hafido1983
Peugeot Pin Code for 407 1.6 HDI Plus DPF delete alexvf750 4 210 12-11-2016 09:59 AM
Last Post: alexvf750
Peugeot Deactivate Airbag warning Peugeot 407 2007 david.obd2 0 158 11-28-2016 05:17 AM
Last Post: david.obd2
Peugeot Peugeot 9HW Engine - no signal to injectors - engine won't start mimsi1 28 1,244 10-31-2016 12:31 PM
Last Post: igauto
  peugeot 407 unlock by itself after 5 minutes mikroel 7 563 10-14-2016 03:00 AM
Last Post: jumpy1
  citroen c4 grand picasso 2009 cooling fan xipsilon 5 246 10-08-2016 06:38 AM
Last Post: xipsilon
Peugeot Peugeot 207 1.6 engine dont start Fukito 10 636 10-08-2016 02:11 AM
Last Post: fanjo
VW 407 2.0 HDI engine stops in driving Tancho 5 298 10-01-2016 01:06 PM
Last Post: klonone
