To obtain your registration ID "Invitation Code", please send your request to: [email protected]
If you are a registered member in MHH and not able to login or recover your account, Kindly contact [email protected]
Post Reply
  • 0 Votes - 0 Average
99 international dt 466
10-21-2017, 07:33 AM
Post: #1
I have this ic truck that ive been trying to running for a friend.
It has a Code DTC 626 SPN 254 FMI 8. active unexpected reset fault *M*
I clear it with service maxx, the pro link, and also service assistance.
it comes right back.
when I try to start the truck it will not start. it spins over ICP goes to 985 to 1000psi. check fuel pressure at the filter housing and I have about 45 psi.
but no start. If I give it a shot of starter fluid it run and stay running until you shut it off. Then if you try to restart right after words it wont unless you give it some help.
Im stump with this IC truck. Thanks for your help!!!!
Find all posts by this user
Quote this message in a reply
10-21-2017, 10:01 AM
Post: #2
RE: 99 international dt 466
What are RPM's when starting? If RPM's are low spray will increase them and get the motor running. How is starter load?
Also that ICP seems high at start, not that its a bad thing to have good ICP, but are you sure your reading "PSI"
If my post is helpful, please click on Thanks and Reputation buttons Handshake
10-21-2017, 10:19 AM
Post: #3
(10-21-2017 10:01 AM)TestProbe Wrote:  What are RPM's when starting? If RPM's are low spray will increase them and get the motor running. How is starter load?
the icp is in psi, I think the rpm gauge is said 300rpm or so
the nexiq will disconnect for a min while trying to start and it reconnects. I don't why it does that?
10-21-2017, 10:53 AM (This post was last modified: 10-21-2017 10:55 AM by IROC.)
Post: #4
626 Unexpected Reset Fault is a voltage fault. It can be set by simply dropping voltage too low while cranking. There could also be some bad wiring with high resistance causing a voltage drop to the ECM while cranking. Starter draw could be too high.
ICP pressure while cranking only needs to be 500 PSI to start the engine. Fuel pressure can be as low as 10 PSI to get the engine started. Cranking speed needs to be somewhere around a minimum of 200 rpm. So everything you've said, those parameters are all within engine starting specs.
I would check the grid heater operation if the truck has one.
These older trucks are common for having the NEXIQ disconnect while cranking. Again, it's a voltage drop thing.
 Thanks given by: wraytechs
10-21-2017, 11:55 AM
Post: #5
(10-21-2017 10:53 AM)IROC Wrote:  626 Unexpected Reset Fault is a voltage fault. It can be set by simply dropping voltage too low while cranking. There could also be some bad wiring with high resistance causing a voltage drop to the ECM while cranking. Starter draw could be too high.
No sir is don't have a grid heater.
10-21-2017, 12:50 PM (This post was last modified: 10-21-2017 01:00 PM by TestProbe.)
Post: #6
Like IROC said, everything sounds within tolerance. Check your voltage & ground to ECM during crank. I think your going to find a loose ground to the ECM and the voltage is dropping enough to drop it.
Do you have additional active codes??
So if you immediately try to restart the engine after running it won't start, correct?
That code usually means there is a problem with the power connections to your ECM which could be anything from loose battery connections to bad ECM power relay. That code translates to 626 which is an unexpected reset DTC.
Look at the small power and ground connectors at the battery which go up to the ECM power relay
 Thanks given by: firefighterf18 , wraytechs
10-21-2017, 01:09 PM
Post: #7
(10-21-2017 12:50 PM)TestProbe Wrote:  Like IROC said, everything sounds within tolerance. Check your voltage & ground to ECM during crank. I think your going to find a loose ground to the ECM and the voltage is dropping enough to drop it.
No other codes.
And that right. You turn it off and try to restart no luck
10-21-2017, 02:23 PM
Post: #8
(10-21-2017 07:33 AM)firefighterf18 Wrote:  I have this ic truck that ive been trying to running for a friend.
Hardwire the clean power and grounds in battery box theu arw the weather pack connection and therevis also one 3 wire down by the starter that will get rid of that fault
Sent from my LG-K540 using Tapatalk
 Thanks given by: firefighterf18 , TestProbe , wraytechs
10-21-2017, 03:26 PM
Post: #9
I will do that first thing in the morning, thank you and I let you know how it turns out
Post Reply
Possibly Related Threads...
Thread: Author Replies: Views: Last Post
  International Navistar Diamond Logic Builder (DLB) Fleet 2015 v15518 + Key jahacmm 118 10,865 Yesterday 06:21 PM
Last Post: jahacmm
  International Navistar Diamond Logic Builder (DLB) 2015 Kg jahacmm 117 5,041 Yesterday 02:08 PM
Last Post: kikis
AA+MHH international maxxforce 13 DPF delete? binhminh410 42 22,906 11-14-2017 04:23 PM
Last Post: SCANIA730
  INJECTOR DISABLE TEST INTERNATIONAL rolando 3 205 10-06-2017 06:26 AM
Last Post: tomacejones
  international wiring diagrams and schematics gerry_foster 3 212 10-03-2017 10:21 AM
Last Post: wildarmz
  International maxforce 13 edc7c32 ACM adf-chiptuning 3 300 09-30-2017 02:42 PM
Last Post: Jonny Rotten
  03 4300 International Rjpierma24 1 130 09-21-2017 08:56 AM
Last Post: IROC
  international spn 4380 Rjpierma24 4 170 09-21-2017 08:47 AM
Last Post: Rjpierma24
  2016 International spn 1569 Rjpierma24 2 266 09-17-2017 06:53 AM
Last Post: Jonathanfl
  Need Navistar International Nets 5.5.1 shawn74 114 13,354 09-13-2017 02:07 PM
Last Post: AlexKyle
User(s) browsing this thread:
1 Guest(s)
