  • 1 Votes - 2 Average
Actia D3 Mux connection problem original Compact 4
11-17-2017, 10:49 AM (This post was last modified: 11-17-2017 10:50 AM by poxxxy.)
Mercedes Benz Actia D3 Mux connection problem original Compact 4
Hi guys,
I got the compact 4 running with help from Anturage, it was a simple fix afterall... however today I attempted to make connection with my vito. The green light on the mux was on and I connected to the rs485 connection on the back of the compact 4 tablet to the mux. However I was greated with the terminal 30 31 error in das when trying to communicate. I decided to see if I could see anything in sdconnecttoolkit but no device was found I also then tried running caesar self test but no device was found.
I guess I will have to try check for continuity on the mux to tablet lead? Currently waiting for an rs485 to rs232 cable to hopefully use it that way. Perhaps RS485 connection on tablet is no good or maybe a problem with mux?
There aren't any settings I can access to try and configure comports etc as far as I can see as the original factory installation is pretty locked down. I mean I guess I could with a bootable OS on USB perhaps. Should I need to?
Any help/experience/advice appreciated.
11-17-2017, 10:59 AM
RE: Actia D3 Mux connection problem original Compact 4
Your problem is in the Toolkit.ini! Check the settings for D part mux ...
 Thanks given by: temo4ka
11-17-2017, 02:02 PM
(11-17-2017 10:59 AM)reem Wrote:  Your problem is in the Toolkit.ini! Check the settings for D part mux ...
Will I need to access this via a bootable OS as I suggested? I only have SDexplorer and no windows file explorer access or cmd.
11-17-2017, 11:38 PM (This post was last modified: 11-17-2017 11:42 PM by reem.)
Which diagnostic version do you use?
XP or Win7,8,10?
11-21-2017, 05:36 AM
Genuine 2013.09 D3 mux and compact 4 tablet with date turned back... appears that a few other sdconnect wifi versions were setup to the tablet too.
11-21-2017, 07:01 AM (This post was last modified: 11-26-2017 01:27 PM by reem.)
Mercedes Benz RE: Actia D3 Mux connection problem original Compact 4
Enclosed is a working configuration of Toolkit.ini file for a Part D Mux. Unpack and replace in the SDconnect Toolkit\bin folder.
After that everything should go...
12-06-2017, 09:54 AM
This doesn't appear to have changed anything, Sad. No sdconnect available via cable when I go into registration and as connect toolkit opens. This was in the programme files folder. Are there's others needed too?
Mercedes Benz Online scn mux c3 xentry 9.2015?? michael130509 10 652 Today 05:45 AM
Last Post: j4g3d
Mercedes Benz SDnetControl recognizes C3 MUX from time to time aths 5 265 02-17-2018 12:46 AM
Last Post: i860
  Vediamo lost connection with ecu remi87 1 180 02-07-2018 07:50 AM
Last Post: Anturage
Mercedes Benz [UPDATED] Workshop Hotspot Connector for C4 MUX v1.1 disinfetor 10 2,520 02-03-2018 05:27 AM
Last Post: autostar
Mercedes Benz Coding a W246 with C3 MUX Piled001 2 205 01-30-2018 09:24 AM
Last Post: gurgel
