  • 29 Votes - 3.21 Average
Actros 2 HM Rear module
10-27-2011, 10:38 PM
Mercedes Benz Actros 2 HM Rear module
Hi maybe some one here can help on a mercedes benz actros 2 you get the rear module (HM located at rear of chassis) which controls lights, suspension, diffs, fuel level, and much more. Now you get different types for example one with air suspension (airbags) and one mechanical (leafspring). I can use a air suspension one on both vehicles but I cant use the leaf spring one on a air suspension truck I have tried changing parameters with das but wont allow me brings up massage that I must use a different control unit and will give me the part numbers. I believe its just the internal data that makes them different because the hardware looks the same to me there is just a cap over the plug connection that controls the airsuspension. Is it possible to copy the Airsuspension data and transfere to the leafspring version maybe by reading/writing the chips or maybe some one knows how to do in das development mode Any advise
Regards
TAW
10-28-2011, 01:54 AM
RE: Actros 2 HM Rear module
i think if u attache some screen shot my i can help Big Grin
PTT2.5 devmode. Euro6 Delete with remote programming, All VOLVO Europe model Adblue delete with remote programming+VOLVO USA 2015 Remote Delete+VOLVO USA DPF&DEF and EGR RemoteDelete or with EMulator D12&d16 EGR Delete http://WWW.AKZODIESEL.COM
01-20-2012, 08:11 AM
(10-27-2011 10:38 PM)TAW Wrote:  Hi maybe some one here can help on a mercedes benz actros 2 you get the rear module (HM located at rear of chassis) which controls lights, suspension, diffs, fuel level, and much more. Now you get different types for example one with air suspension (airbags) and one mechanical (leafspring). I can use a air suspension one on both vehicles but I cant use the leaf spring one on a air suspension truck I have tried changing parameters with das but wont allow me brings up massage that I must use a different control unit and will give me the part numbers. I believe its just the internal data that makes them different because the hardware looks the same to me there is just a cap over the plug connection that controls the airsuspension. Is it possible to copy the Airsuspension data and transfere to the leafspring version maybe by reading/writing the chips or maybe some one knows how to do in das development mode Any advise
Regards
TAW
in HM using F6
Версия БУ Актуальный:
(DV 261 / Re l. 3a )
Актуальный:
(DV 261 / Re l. 3)
СТАРЫЙ:
(DV 260 / Re l. 2a )
СТАРЫЙ:
(DV 260 / Re l. 2)
СТАРЫЙ:
(DV 258 / Re l. 1)
Полная версия 001 446 26 17 (MAPPS x2 /
Reed x1)
001 446 22 17 (MAPPS x2 /
Reed x1)
001 446 18 17
(Reed x2)
001 446 14 17
(Reed x2)
001 446 10 17
(Reed x1)
4x2 001 446 27 17 (MAPPS x1) 001 446 23 17 (MAPPS x1) 001 446 19 17
(Reed x1)
001 446 15 17
(Reed x1)
001 446 11 17
(Reed x1)
6x2,
A00/ CD9
001 446 28 17 (MAPPS x1) 001 446 24 17 (MAPPS x1) 001 446 20 17
(Reed x1)
001 446 16 17
(Reed x1)
001 446 12 17
(Reed x1)
Полный привод 001 446 29 17 (MAPPS x1) 001 446 25 17 (MAPPS x1) 001 446 21 17
(Reed x1)
001 446 17 17
(Reed x1)
001 446 13 17
(Reed x1)
Таблица распределения: Номер детали блока управления + (Вариант датчика уровня топлива x Число датчиков топливного
бака)
Указания:
Вариант датчика уровня топлива: 'Reed' = Дата производства < 12/2006
Вариант датчика уровня топлива: 'MAPPS' = Дата производства > 12/2006
Код A00 = Полностью воздушная подвеска / Код CD9 = Система регулирования поперечных колебаний
Блок управления '001 446 28 17' установлен в а/м.
При новых заказах доступна только полная версия.
Название файла: F:\Programme\Das\bin\..\trees\lkw\hm\hmmp200\hilfe\HHMx0000.s
Координаты
ячейки:
19 , 4
 Thanks given by: faryad88 , TAW
Volvo VOLVO Rear Axles Training CD Image Paya Faraz 0 146 Yesterday 07:58 PM
Last Post: Paya Faraz
Mercedes Benz how to cancel adblue/bluetech professional way (actros..axor) ilyas swaleh 14 4,225 Yesterday 11:10 AM
Last Post: ilyas swaleh
Mercedes Benz Change Actros Speed Limit webmaster 25 19,949 11-17-2017 02:21 PM
Last Post: autovei
Mercedes Benz Mercedes Actros all fault code list lako 0 94 11-17-2017 02:18 PM
Last Post: lako
Mercedes Benz XDOS FOR EURO6 ACTROS SPEED LİMİT FİX oender 1 438 11-17-2017 01:40 PM
Last Post: autovei
Mercedes Benz ACTROS MPIII AUTOMATIC IGNITION OFF shafiq jat 0 78 11-17-2017 08:59 AM
Last Post: shafiq jat
  Detroit Rear Axles camerondiek50 0 70 11-05-2017 04:00 PM
Last Post: camerondiek50
  Mercedes Actros Euro2 PLD full dump szenti71 0 114 11-02-2017 10:29 AM
Last Post: szenti71
  actros file tas_daz 4 194 11-02-2017 03:50 AM
Last Post: tas_daz
Mercedes Benz Need Cbf mercedes temic pld Atego Actros euro 4 raffaell0 5 277 10-30-2017 12:04 AM
Last Post: pesona
