  • 35 Votes - 2.83 Average
Alldata 10.53 Torrents
01-24-2014, 08:23 AM (This post was last modified: 01-24-2014 11:28 AM by ceeya13.)
Post: #28
RE: Alldata 10.53 Torrents
(12-20-2013 07:23 AM)itsformetoo Wrote:  Here you will find a torrent for Alldata 10.53 complete
It is over 500 gigs in four torrent files. Have fun
This is the only crack works perfect with alldata 10.53 with NO issues whatsoever made by Olly99, After you install alldata 10.53 (don't apply the patch) use DiscCopy to your data THEN apply the patch.
(it's been in this form a long time : http://mhhauto.com/Thread-Alldata-10-52-...ht=alldata )
while the other crack which marked 10.52SS has the problem with 10.53 and been made by Visroni.
Attached File(s)
alldata 10.52 patch by Olly99.rar
File Type: .rar
Downloaded: 1076 times
 Thanks given by: impaler11 , scanjunky , onewhizard , ssqxczc , Face155 , xeonx2 , 153771739 , letnI , psyentist , rcs , carsoftobd , mikycar , fdiazv1757 , Yangseonkim , kodiran , syedamir41 , moham6e6 , phap.mer , sec5klp , hamr2013 , ohin , Towexperts , mmart444 , macdragin , Francesca , Huevin , josebapol , thanhtung3000 , Yerbamate , Wilecoyote , Docfxit , johndoejr , rrador , Chakallo , PATO , bouboule2000 , 1mouse3 , smlee747 , khalid farhan
01-24-2014, 01:36 PM
Post: #29
Same problem as before,,,downloaded all Domestic discs from 1st part again and still the same problems,,new olly99 patch has no change,,still no or only part of first 16 Domestic disc not reading correct,,still says wrong data for version. All import discs are working corrects as far as i can tell.
01-24-2014, 03:33 PM (This post was last modified: 01-24-2014 03:37 PM by ceeya13.)
Post: #30
(01-24-2014 01:36 PM)scanjunky Wrote:  Same problem as before,,,downloaded all Domestic discs from 1st part again and still the same problems,,new olly99 patch has no change,,still no or only part of first 16 Domestic disc not reading correct,,still says wrong data for version. All import discs are working corrects as far as i can tell.
Looks like even you have original 10.53 with original key, you will have the same problem because you have a bad copy disc's.
what I have are a copy from the original disc's (belongs to a friend) and working with Zero error.
01-24-2014, 05:33 PM (This post was last modified: 01-24-2014 05:35 PM by itsformetoo.)
Post: #31
The Russian site updated the link Jan. 15 /14, you have to restart the link, a recheck will not work.
01-24-2014, 06:17 PM
Post: #32
Not sure what a "recheck" is,,but i clicked the link on the original post at the start of this message and downloaded another 122GB of files that included all 16 domestic discs and they did not work any better than the first 122GB of files I dowloaded the first time. What ever they updated still doesnt work. If im wrong can you give me any insight as to what link to download all the domestic discs from??
01-25-2014, 08:34 AM
Post: #33
(01-24-2014 06:17 PM)scanjunky Wrote:  Not sure what a "recheck" is,,but i clicked the link on the original post at the start of this message and downloaded another 122GB of files that included all 16 domestic discs and they did not work any better than the first 122GB of files I dowloaded the first time. What ever they updated still doesnt work. If im wrong can you give me any insight as to what link to download all the domestic discs from??
This is the link "h**p://dl.rutracker.org/forum/dl.php?t=4617033"
At present everyone is asking for seeders, there are none, so if you downloaded before Jan 15 you have the bad copies.
you must delete the old torrent and start again.
The forum link is "h**p://rutracker.org/forum/tracker.php?nm=alldata"
 Thanks given by: scanjunky
01-25-2014, 12:05 PM
Post: #34
Thank you very much for the help,,yes your right,,nobody is seeding anything,,,
01-25-2014, 01:44 PM (This post was last modified: 01-25-2014 01:52 PM by bigcid10.)
Post: #35
Toyota RE: Alldata 10.53 Torrents
(01-09-2014 07:20 AM)uhaulkid Wrote:
(01-08-2014 09:24 PM)Ricky67 Wrote:
(01-07-2014 11:46 AM)scanjunky Wrote:  Is anyone having trouble with the program not recognizing the Domestic discs DM01 thru DM16, it is telling me in the error code that the data is not 3rd quarter 2013 but everything in the folders says it is. There is no problems with any of the 70 import discs,,they all read correct. Its only the Domestic,,and on disk DM01,,some of the cars will come up and work, the chryslers only. maybe its just the 10.52 cracked program,,was wondering if anyone had come across this problem yet? I have downloaded the domestic discs 2 times just to be sure that i didnt have a failed download and corrupted the data.
I have the same problem, DM01, 03,05,06,07,12,13,14,15, and 16.
And when I copy over ace.exe when I start Alldata is 10.52 SS? not 10.53?
Anyone have an idea what I have done wrong?
your not doing wrong, all the posts about 10.53 ARENT .53 they are 0.53 data with .Visronis 10.52 crack that was leaked here by someone here. thats why he got smart on his cracks and labeld them so if its given away hell know who had it by the tag in it..
It has to be a download problem from the torrent because I just checked my domestic disks and there fine
Plus I'm using the 10.52ss Patch and I can't find any part of alldata
that I can't use that's relevant for everyday use
Although I was using Danilko's files,not from the torrent
01-25-2014, 02:44 PM
Post: #36
I use a patch that does not contain the ss crap!
"Two there should be; no more, no less. One to embody power, the other to crave it."
If this helped you click the thanks button!Fing32
 Thanks given by: Face155 , AutoAlex
AA+MHH ALLDATA 10.53 Full Set 2013.Q3 on 90xDVD (1982-2014) alba1 62 54,411 01-10-2017 09:42 PM
Last Post: chevy664
AA+MHH Alldata 10.53 On torrent ALL DISKS!(No password) khomrericky 2 2,768 07-27-2016 10:32 PM
Last Post: khomrericky
Mercedes Benz Mercedes EPC 06.2016 1st Web Release Torrents Dali01 0 505 06-23-2016 01:08 PM
Last Post: Dali01
AA+MHH AllData+10.53+Import Discs bensaid66 2 2,882 03-20-2016 08:53 PM
Last Post: Loucas
  ALLDATA 10.53 IMPORT alba1 0 1,116 02-12-2016 11:19 AM
Last Post: alba1
  AllData 10.53 Setup With All Domestic Discs 1982 – 2014 alba1 0 1,404 02-12-2016 11:14 AM
Last Post: alba1
  looking alldata for domestic vehicles ashu01 5 858 02-02-2016 07:14 PM
Last Post: DieselTech1
AA+MHH alldata 10.53 problems catskinner 10 4,122 01-05-2016 04:32 AM
Last Post: patipravat
AA+MHH ALLDATA portable 10.53 slikgsr 3 6,079 11-08-2015 01:35 AM
Last Post: affa
AA+MHH AllData 10.53 Import and All-Domestic Discs 1982-2014 alba1 17 15,974 10-30-2015 12:46 AM
Last Post: ronald
2 Guest(s)
