  • 17 Votes - 3.12 Average
Assist in program epc mercedes
08-17-2012, 12:23 AM
Post: #10
RE: Assist in program epc mercedes
(08-12-2012 02:30 PM)Pluto Wrote:
(08-12-2012 06:06 AM)madico2000 Wrote:  Hello to all
I just installed the Ewa Net 2012. Wis/Asra program working fine.I just downloaded the EPC data. when i want to install the epc data from Admin Tools, it gave me an error.all the epc 3 cd's are complete.
pls view attach error.user is created.
thank you in advance
Good evening M8Cheer2
You should look at Mr Patrians posts--he always says he does not use the "shity" new admin tool which you used. That is your problem.1087
Others may have a better solution, however I would start over and use the EWA Clean Tool then and after you have installed the EWA net from the first disc(b1)---go to the read me\support file on the first disc( b1) and drill down till you find the "classic admin tool icon" that Mr Patrian uses and install(double click) ------then finish with the EWA group requirements and then install the EPC and WIS database and all will go well. Good LuckBeerBeer
Hello Mister
i just follow your advice. I clean all ewa net from my computer. I restarted. i launched the epc b1 cd and search for "ewa admin tool classic" i attached a jpg file for more explications.
thank you for your help.
Attached File(s) Thumbnail(s)
11-23-2012, 02:31 AM
Post: #11
Mercedes Benz unlock Code for wis epc
can I have an unlock code for wis epc?
LAN-ID=000FB0A24A33
thanks
11-23-2012, 02:50 AM
Post: #12
Mercedes Benz RE: unlock Code for wis epc
(11-23-2012 02:31 AM)Teoz Wrote:  Hi,
LAN-ID=000FB0A24A33
thanks
EPCnet: 4QAE4SPJAWCAFCCQD7FSQ49RDS6JSPYASNZD4JHJC7HCQCWB
WISnet: PJTXXKETLQAQH4F8A46KDW5HN8C6ZP8HB7AMGL87FPN22N7E
If it my post is helpful, please push [Image: postbit_reputation.gif] and press [Image: postbit_thx.gif] to me . . . .
11-23-2012, 06:55 AM
Post: #13
power sreering mb210
11-23-2012, 07:02 AM
Post: #14
Mercedes Benz RE: Assist in program epc mercedes
(11-23-2012 06:55 AM)ergyssela Wrote:  power sreering mb210
Good Morning M8Cheer2
And your question is !!!!!!1087
11-24-2012, 08:29 AM
Post: #15
210-460-01-11
Maybe he needed the part number.. Cheer2Fing322424
12-09-2012, 10:25 PM
Post: #16
hi all
i need ur help: it looks like my start keys for WIS/EPC have expired ... -> please have a look at the screenshot attached, at the bar right below the Merc star
can any1 help me with new start key?
Current MAC address (LAN-ID): B2A2CF63047C
thank you
12-09-2012, 11:41 PM
Post: #17
(12-09-2012 10:25 PM)adispan Wrote:  hi all
thank you
Perhaps you have changed to another network card (like from LAN to WLAN).
You could have created new keys with the kg that is shared at this site but if you don't want to have that effort, here you have new keys:
EPCnet: UWJQQXH8MUHGJJPLELFHK4MGXGEG27QB37XZF9RBNXSVLM77
WISnet: L3YC2VLHJVDKQSPSJWH2592ZBLCPM64XC992XAVRY6BDY554
12-10-2012, 08:42 AM
Post: #18
thank you DBmhh
2day i remembered i made a swap between laptops, when the laptop where i installed epc crashed - i took the HDD from the damaged laptop and put it in another laptop, identical to the one i had Smile)
i didn't know there is a kg on the site, when i installed epc there was a thread where i requested the codes, i didn't know abot the current kg
i took the codes you gave me, but no luck; i replaced the old codes with these, but i am facing the same problem; i probably need to uninstall and reinstall epc
thank you once again for the help
Mercedes Benz Mercedes EPC & WIS [Discussions/Problems] Fouad 822 295,147 Yesterday 11:25 AM
Last Post: omega1
Mercedes Benz mercedes benz epc key generator with datacard !!! ttmtt 4 729 05-19-2018 02:21 AM
Last Post: ardicela
  W166 ML350 blind spot assist disabled bawarek 9 1,044 05-13-2018 04:08 PM
Last Post: bawarek
  SLA & Attention Assist Retrofit Query Gibsonk 1 363 04-28-2018 08:50 PM
Last Post: Jake5555
Mercedes Benz W205 Enable speed limit assist mate11 13 2,074 04-22-2018 07:06 PM
Last Post: likemovie
