  • 32 Votes - 3.47 Average
Astra G 1.7 DT will not start
01-23-2013, 10:30 AM (This post was last modified: 01-23-2013 10:44 AM by kalelarga.)
Opel Astra G 1.7 DT will not start
Hi to all!
I have Opel Astra G 1.7 DT MY 2001, engine will not start.
Here is diagnostics data:
OP-COM 100219a - PC based diagnostic tool
OP-COM - KW2000 Communication Window> 2001 (1)|Astra-G|Engine|Y 17 DT
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: Not programmed
RepairShopCodeOrTesterSerialNumber: Not programmed
ProgrammingDate: 00000000
systemSupplierECUHardwareNumber: DEL 0113386350
vehicleManufacturerECUHardwareNumber 97240621 EA
systemSupplierECUSoftwareNumber: DLNF
systemSupplierECUSoftwareVersionNumber: 0002
exhaustRegulationOrTypeApprovalNumber: D01008
systemNameOrEngineType: Y17DT
Identifier: 1305
CalibrationDate: STRCB0A
Total number of fault codes: 2
P0602 - Control Module Programming Error
(00) - Present
P1610 - Immobiliser Function not Programmed
(00) - Present
When read ECU data with CarProg,
ECU Delco 1.7l Diesel ECU v.0.15 :
immobilizer < - > ECU sinchronization data: 00000000000000000000000000000000
PIN: 0000
VIN: 0
How can I read PIN code from immobilizer box?
VagTacho & OPEL immo interface, OpCom, Opel Can Scanner, Carprog...?
Immobilizer 2 : No fault codes stored!
Please help!!!
01-23-2013, 04:11 PM
RE: Astra G 1.7 DT will not start
pin can be read from the immo box, post file to help. open the ecu(hybrid) to see if it is not filled with disel it is a common problem
 Thanks given by: kalelarga , webmaster
01-24-2013, 02:55 AM
open ecu think You can have fuel there if You have tech2 You can also make SPS
VW Do not start passat B6, help khassani 2 206 06-05-2017 08:14 PM
Last Post: geneluauto
Peugeot peugeot 607 2.7 hdi year 2005 not start dtc U1218 , U2000 manueldord 11 431 06-03-2017 01:03 AM
Last Post: manueldord
Opel 0281031157 edc17c59 gpt opel start first time and now doesn't start after write lele89ca 18 746 05-29-2017 05:26 AM
Last Post: lele89ca
  w202 not start 24c04 virgin REPROARTE 4 428 04-03-2017 10:18 AM
Last Post: diagnostico
BMW E60 not start mikeburnet 3 147 03-31-2017 01:31 AM
Last Post: mikeburnet
VW VW Golf 7/8?? No start/crank after reverse jump start Sparky001 3 290 03-20-2017 07:08 AM
Last Post: Sparky001
Audi ME 7.1.1 do not start after OBD flashing Audi A6 andbar2 3 241 03-07-2017 05:47 AM
Last Post: andbar2
  bmw serie 1 e81 2006 dtc 4A62 not start manueldord 0 160 01-18-2017 01:18 AM
Toyota toyota corola not start immo problem zkutnja8 6 377 12-19-2016 12:57 PM
Last Post: zkutnja8
BMW BMW E90 write problem OBD no car not start joe1953 7 582 10-29-2016 04:15 PM
Last Post: teefyg1
