Audi A6 2.5TDI 150HP Replace ECU.
08-12-2017, 07:03 AM
in few days I will have Audi A6 2.5tdi 150 hp to replacement ECU, because old is probably damaged.
I think there is EDC15P+ or VM+, right?
Will be enough for immo that I will copy eeprom from old to new ECU? Or do I need something more to do to copy immo?
Regards!
If helped hit "+Thanks" and "+Reputation" button Smile.
If wrote something interesting also click on "+Thanks" Smile.
Have a nice day.
08-12-2017, 07:06 AM
RE: Audi A6 2.5TDI 150HP Replace ECU.
swap eeprom and copy your flash over , if its the same numbers just eeprom
 Thanks given by: razor1199
08-18-2017, 11:38 AM
Ok, this is old ECU with 5 plugs, inside is 24C04 eeprom, if I swap eeproms (ECU's are the same numbers) should car start or will be problems with coded pump?
Have a nice day.
08-18-2017, 11:42 AM
not sure if its not a EDC15P+ , post picture someone will know
08-18-2017, 11:59 AM
It's ECU like this, I will have it on tuesday.
[Image: 0059600_000-196-024-001-7953cc08-fb64-41...2aca5.jpeg]
Have a nice day.
08-18-2017, 12:18 PM
This is old ecu with two plcc 32. Maybe swap hh+ll+immo to new ecu. version vm/+ have also immo in pump.
08-18-2017, 12:19 PM
its the small 8 legged one above main chip
[Image: 5023615800_1329957337.jpg]
08-18-2017, 12:34 PM (This post was last modified: 08-18-2017 12:57 PM by razor1199.)
I'm not sure if the old one has bad maps, that's why they asked me for replace.
I forgot there is no coded pump, Simial is right. So if I will do immo off (isn't it in eeprom?) or swap eeproms I should have working car? Smile
Have a nice day.
08-18-2017, 02:05 PM
yess only eeprom needed, or make immo off in eeprom
no immo in flash for this one
VW VW T5 2,5tdi hotstart PedroX5 2 100 08-17-2017 05:46 AM
Last Post: PedroX5
Alfa Replace ecu with different Bosch number alfoldi.mate 0 106 08-16-2017 11:22 AM
Last Post: alfoldi.mate
Mercedes Benz 722.9 vgs replace OFFLINE step by step instructions using FVDI tpresser 45 36,253 08-16-2017 12:14 AM
Last Post: Bibobabo
  hi immo off for audi a6 2.5tdi 2001 dr..ecu 5 250 07-24-2017 06:30 PM
Last Post: plasticman1971
Audi PIN from 4b2907401b Audi 2.5TDI 180hp TDI_TEAM 8 566 07-24-2017 08:14 AM
Last Post: TIGRI007
Mercedes Benz W211 Vgs 722.9 replace need help please apluslock 5 186 07-18-2017 04:46 AM
Last Post: apluslock
VW VW 2.5TDI AUTOMATIC TO MANUAL GEARBOX HELP ELEKTROAUTO_Eraldi 2 160 07-16-2017 06:56 AM
Last Post: loki954
Skoda Skoda Superb 2.5tdi immo off marpaj 7 228 07-16-2017 06:01 AM
Last Post: nerko82
Audi audi 2.5tdi vp44 Cieniu 2 252 07-16-2017 05:57 AM
Last Post: nerko82
Audi Need PIN and IMMO OFF Audi C4 2.5TDI WorldGSM 4 196 07-15-2017 11:44 PM
Last Post: WorldGSM
