  • 1 Votes - 4 Average
BMW E60 BOSCH ECU virgin
01-12-2017, 12:15 AM
BMW BMW E60 BOSCH ECU virgin
Hi guys,
please anyone to virginise the BOSCH HW no: 0 281 013 500 to make it plug and play again. Ori file by Kess via OBD is attached.
Broken after a battery change or a jump start. It does not allow to crank.
It throws DTC: 4A63 and 4212 and won't let me diagnose it completely with INPA.
CAS is OK without any DTCs.
ECU SW is : 1037387658, BMW : DDE 7 803 369
In case I can send a files from CAS and/or the ECM BDM too.
Thanks for any help Smile
Attached File(s)
BMW E60 ECU ori.rar
File Type: .rar
Downloaded: 2 times
01-12-2017, 12:24 AM
RE: BMW E60 BOSCH ECU virgin
I don't think kess file will help here. If you want good working solution, you need to send bdm of ecu and cas, too. "Immo" is in eeprom.
 Thanks given by: bawarek
01-12-2017, 09:41 AM (This post was last modified: 01-13-2017 01:38 AM by sazimam.)
BMW RE: BMW E60 BOSCH ECU virgin
Here you are the BDM files from the DDE
Right now I am working on a CAS data extract.
EDIT > - CAS data cannot be read, 0L01Y won't let me in Sad
Attached File(s)
BMW E60 DDE ori.rar
File Type: .rar
Downloaded: 4 times
01-12-2017, 09:50 AM
Why make it virgin? And why make it so complicated?
BDM it and write it over to new ecu.
01-13-2017, 01:37 AM (This post was last modified: 01-13-2017 02:10 AM by sazimam.)
(01-12-2017 09:50 AM)sigaik Wrote:  Why make it virgin? And why make it so complicated?
I have no new ECU. My guess is, there was a glitch in communication and something was incorrectly overwritten, but the ECU itself is OK.
I just need to reprogram it back to normal operation.
CAS3 / DDE matching does not work - failed /not in ordnung/
So do you have a full BDM for this just to test it, please?Sweating
Maybe I just need healthy new original file....
  bmw e36 bosch ecu dump file O2 sensor remove please iyad.nasser 3 56 Today 10:15 AM
Last Post: aimanad_101
  How to Virgin'ize ECU adranbu 1 70 Today 03:39 AM
Last Post: sigaik
Renult Megane III 1.4 petrol valeo ecu virgin needed ACDC 2 108 Yesterday 12:57 AM
Last Post: techdoc
  W203 Adapt Ecu after make Virgin joe1953 9 202 01-13-2017 03:27 PM
Last Post: rmp_silva
  E77 Bosch ACDelco Virgin help julespatch 0 74 01-11-2017 11:18 AM
Last Post: julespatch
  BMW E60 CAS2 - burned element. _TrotyL_ 4 132 01-10-2017 10:16 PM
Last Post: _TrotyL_
  BMW E60 525d 0281012190 full BDM and eeprom Evi 4 2,224 01-08-2017 09:13 AM
Last Post: cloner78
BMW Help Virgin BMW ME9 ltfadl 3 135 01-06-2017 09:38 AM
Last Post: jasnicdusan
Alfa Ecu ME7.3.1 alfa 95080 swap or virgin 2longue 7 200 01-06-2017 12:19 AM
Last Post: 2longue
  it's possible virgin ecu dacia logan delphi dcm 3.4 hafido1983 4 794 01-03-2017 02:29 AM
Last Post: mohcin2
2 Guest(s)
