  • 1 Votes - 1 Average
BMW E70 CCC failed after update
12-18-2017, 12:00 PM
BMW BMW E70 CCC failed after update
After update flash with winkfp i have "signature check failed" at 100%. Now the programstate is 5.
i tried many things. Update with ISTA-P also ends with failure. i update with k+DCAN cable.
I tried with CCC repair cd but i got "HOST - error 221" on display at start.
HW is 12.7
Please can anyone help? i will pay for it 100%.
12-18-2017, 01:19 PM
RE: BMW E70 CCC failed after update
CCC is flashed with ICOM.
With K + DCAN it usually comes to error messages and breaks off.
And an order must be kept.
 Thanks given by: bawarek
12-18-2017, 10:45 PM (This post was last modified: 12-18-2017 10:47 PM by NTAuto.)
Yes i know that :-) But its to late now.
I also tried flashing in correct order, but its still same.
Question is how to resque it now???
Is it possible to solve the problem if i buy ICOM A2 and reflash with ISTA P?
12-18-2017, 11:10 PM
Had one's same situation, I end it up sticking CCC in to a freezer for 24 hours at -10 and then flashing on bench, it was sexes.
12-19-2017, 12:07 AM
Why should freezer help??? :-)
12-19-2017, 12:18 AM
When chips get to hot (which could be while programming) they loose contact with pcb or have internal connection problems. Usually BGA flash and sh4 processors fail on them.
But before freezing things down try to get an icom with MOST adapter and flash with ista p
12-20-2017, 04:24 AM
(12-19-2017 12:18 AM)Bibobabo Wrote:  When chips get to hot (which could be while programming) they loose contact with pcb or have internal connection problems. Usually BGA flash and sh4 processors fail on them.
That the right discrimination why freezer
12-20-2017, 09:14 AM
i ordered a genuine ICOM next A+B interface. I will try update with ISTA-P when i recieve the ICOM.
And report Blush
12-20-2017, 12:11 PM
Where can i get original Icom?
BMW Bmw e70 2012-7 hagop 0 241 Yesterday 04:49 AM
Last Post: hagop
BMW Get FSC into CCC E60/E61 Pogo 0 543 04-20-2018 10:30 PM
Last Post: Pogo
BMW BMW E60 ccc repair vlajko 98 233,585 04-16-2018 09:34 AM
Last Post: juht
BMW BMW X5 E70 COOLING FAN NOT WORKING mkwila 1 1,804 04-08-2018 10:41 PM
Last Post: Willisodhiambo
BMW Module CCC e87 k-amer 1 879 04-06-2018 09:39 AM
Last Post: hojo29
