  • 1 Votes - 1 Average
BMW F48 head lamp full led coding problem
10-23-2017, 07:58 AM
BMW BMW F48 head lamp full led coding problem
i have 2016 bmw x1 F48 from US , i have change headlamp from led US lamp to full led Eu lamp . angel eyes work but low beam and high beam led lamp only blink and go off . in attachment photo with fault codes from ista . What i have to change in coding ? I know coding with ncs expert , but esys its new for me , i stil have problem with pszdzdata for F48 and i dont know how make coding
Attached File(s) Thumbnail(s)
10-25-2017, 01:15 AM
RE: BMW F48 head lamp full led coding problem
Can you write your vin number, i will try to give you solution.
10-25-2017, 04:02 AM
(10-25-2017 01:15 AM)kalabalak Wrote:  Can you write your vin number, i will try to give you solution.
Thanks for reply, VIN : WBXHT3C30G5E51112 , and new us headlamp number 63.11-7430472 -01 , 63.11-7430471 -01
10-26-2017, 12:34 PM
As i can see Body Domain Controller is the same from eu and us so the most easy way should be to try encoding FLE_L and FLE_R with ista/p
10-27-2017, 10:19 AM
I did this already, befor the headlights did not work at all
10-29-2017, 01:20 AM
You can try to remove 5A4A from vehicle order and do full encoding on every ecu in the car
10-30-2017, 12:54 AM
thanks il try
10-30-2017, 02:50 AM
You can also do it with esys
Reserve Icom with itoolradar, start esys, establish connection, (top left corner), choose F056 (without _DIRECT), then on left EXPERT MODE > Coding > read FA, read SVT, then search for FLE on list and click with right button and select code, then search for second FLE and also click code. Do no ever use CODE DEFAULT VALUES.
BMW Coding Programming Retrofitting
Mercedes Benz Coding Retrofitting
Online help by TeamViewer
CID Changeable SD cards! 100% working!
10-30-2017, 12:27 PM
thaks for reply , yes i have but with ncs expert or ista , with esys its my firs steps . I stil have problem with right pzdzdata for f48
  Coding early E38, INPA connection problem Willisodhiambo 11 663 Yesterday 10:30 PM
Last Post: Willisodhiambo
BMW BMW NBT EVO ID5 ID6 Video In Motion Coding Mafiemek 6 1,682 04-06-2018 10:50 AM
Last Post: aimanad_101
  BMW F30 remote coding and esys install koket 18 3,741 03-27-2018 09:29 PM
Last Post: iyad.nasser
  BMW i3 e-sys coding Autokorektas 1 1,159 03-23-2018 01:19 AM
Last Post: Autokorektas
  Bmw e46 m3 zcs coding Automoe 9 1,482 03-18-2018 07:26 PM
Last Post: Automoe
