BMW S63B44O0 header swap from S63B44T0, Oxygen Sensor problem
10-24-2017, 12:36 AM
Dear friends,
On BMW X5M engine S63B44O0 there is exhaust header like this:
[Image: p90045732_image-1600x1200.jpg]
We replaced it with header from BMW M5 F10 engine S63B44T0, headers like this:
[Image: b6ac51020d7c.jpg]
As You can see X5M headers are pulsing cyl 1-4 in one turbocharger so left oxygen sensor after turbo reads from 1-4 cyl and right oxygen sensor reads from 5-8 cyl.
In M5 F10 the exhaust header is divided, so there is better pulse flow to turbocharger but problem is that now left sensor reads o2 from cyl 1,6,7,4 and right reads from cyl 5,2,3,8.
Remap with datalogs before was no problem, now after few days or week ecu gives error "Oxygen sensor left before cat mixed up sides" and same for right.
PP Performance and some others have done it with no codes or limp mode.
Maybe someone have experience in this or any ideas?
10-25-2017, 06:23 AM
RE: BMW S63B44O0 header swap from S63B44T0, Oxygen Sensor problem
Anyone?
10-26-2017, 05:14 AM
Recognition interchanged Lambda-Probes Before KAT
Codeword for DLSUV
WinOLS + DAMOS Importer+DAMOS Translator
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles)
 Thanks given by: janisk
11-06-2017, 10:33 AM
(10-26-2017 05:14 AM)telucu17 Wrote:  Recognition interchanged Lambda-Probes Before KAT
Codeword for DLSUV
Hi, thank You for Your reply.
Of course i tried exchanging them place before KAT, than after KAT and then both. Its always same error about mixed sides.
Any ideas?
Thank You.
11-06-2017, 10:35 AM
Codeword for DLSUV
Any ideas?
Thank You.
need to disable this function in your software bro
Vauxhall corsa vxr nurburgring cat 1 delete , o2 sensor management light corsa_vxr_chris 0 79 11-07-2017 03:07 PM
Last Post: corsa_vxr_chris
Opel 02 sensor help opel/vauxhall corsa opc/vxr corsa_vxr_chris 9 188 11-06-2017 04:10 AM
Last Post: G.a.z
Audi Help, add MAP sensor A3 TDI 8P Ecudynamics 3 132 11-03-2017 09:45 AM
Last Post: lsdlsd88
VW VW Crafter remove AdBlue and Nox sensor MB_W230 4 276 10-22-2017 11:56 AM
Last Post: mariusica_boy
  Seat 1.9 tdi EDC 15 need 4 bar map sensor Turbo.Garage64 2 145 10-19-2017 12:38 AM
Last Post: MK2-VRT
  Opel AgilaB O2 2nd sensor Kikko530d 0 45 10-18-2017 03:25 AM
Last Post: Kikko530d
BMW BMW z3 swap 2.0 2.8 update ROM leebaron 0 74 10-11-2017 03:40 AM
Last Post: leebaron
  Bmw edc16c35 rail sensor lineralization papi123 2 109 10-06-2017 10:02 AM
Last Post: papi123
  Need help install map sensor tdi lameiramen 1 122 09-27-2017 02:16 AM
Last Post: billi
  Cleaning DPF or replace difference sensor? razor1199 4 223 09-26-2017 06:54 AM
Last Post: razor1199
