BMW auto trans to manual
10-22-2017, 08:26 AM
BMW BMW auto trans to manual
Hi friends!
Please help!
I convert BMW 320d e46 2001 automatic trans to manual trans.
Dash coded by ncs ... OK
DDE how coded? ncs no listing.
Which ECU should be still?
I am a novice BMW ....
Thanks!
10-22-2017, 08:29 AM
RE: BMW auto trans to manual
you need to recode ews not ecu
REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
Skype: aemtuning
dont ask for free files
sgo/frf bin converter
10-22-2017, 08:49 AM
(10-22-2017 08:29 AM)aemtuning Wrote:  you need to recode ews not ecu
The ews are not immo?
I use the original ecu, automatic ecu (dde).
10-22-2017, 11:34 AM
Go to realoem.com, find manualy (not from vin), your ecu, check soft number for manual and automatic transmision, when nr is different note nr manual trans. ecu soft. Find this nr in ncs, when no exist find good dathen file to e46. Reprogram ecu, make synchro ews to dde, jobs done.
Good luck
 Thanks given by: gelencserg , KriyenKPp
10-30-2017, 09:46 PM (This post was last modified: 10-30-2017 09:46 PM by gelencserg.)
(10-22-2017 11:34 AM)konop11138 Wrote:  Go to realoem.com, find manualy (not from vin), your ecu, check soft number for manual and automatic transmision, when nr is different note nr manual trans. ecu soft. Find this nr in ncs, when no exist find good dathen file to e46. Reprogram ecu, make synchro ews to dde, jobs done.
Good luck
Can you help her?
I do not understand which software I will upload.
The car: 320D M47 2000 "Touring lhd 136le
0281010205
ECU:
  E46 with GM auto transmission - loss of power in overdrive Willisodhiambo 13 2,457 03-24-2018 03:22 AM
Last Post: papenzzo
  BMW E46 330D AUTO GEARBOX Problem Lunacy 0 514 02-06-2018 01:34 PM
Last Post: Lunacy
BMW auto to manual conversion ms41 BobbySD 8 399 01-22-2018 12:10 AM
Last Post: driiiven
  R56 MEV1722 ECU replacement manual/auto problem l0x2 16 2,903 01-03-2018 05:59 AM
Last Post: paco88
  BMW E46 330D 204CV 2004 Auto Gearbox Lunacy 10 3,808 12-11-2017 11:34 AM
Last Post: Lunacy
