Bad / Possessed sd connct c4 or ?
04-21-2018, 11:15 PM
Hi
I really need some help.
After owning a c3 mux with no problems on two cars 2004 slk r171 350 and 2008 c280 w204, das, xentry and vediamo I decide to buy a sd connect c4.
I bought one from China, arrived insert batteries and did the update on Sd connect. Plug the SD in my w204 and all ok, Xentry and vediamo. After a few hours i plug the SD in my slk and no connection in das or vediamo.
Flash the updates again ad after 2 hours the sd suddenly decided to connect DAS and Xentry.
https://imgur.com/a/OPPom
https://imgur.com/idDoSbz
Next day I tried with no luck on both cars.
https://imgur.com/a/5ol6v
I decided to do a fresh install of Xentry 03.2018 and vediamo 05.01.01 on w7 x86 ultimate. All the fixes have been applied by the MHH member (I am very grateful for all your help).
After all, this same thing will connect to w203 and not on slk 350. Flash again the update on sd and at one point will connect with slk but will not connect with w204.
Last time will not connect to any cars.
I always put charged batteries inside, on the SD there is no error only when in not connecting with w204 the red light will flash and xentry will advise me that there is no ignition ( but when is working all modules are detected in the quick test ).
In self-test at the beginning, it was a UART error.
https://imgur.com/3OOzFeO
When is working the SD is ok and see all modules even tried online for updating the transmission ( helped by a member here ) but WHY is not working all the time, is like an old tv he needs time to warm up??
It might work ok on w204 but when connected to slk will stop working, after this will not work on w204 also, need to flash again, restart pc, reboot sd etc...
Are the cars extreme one 2004 and one 2008 ( but again c3 will work ok when swapping between cars )?
Thank you in advance and also many thanks to whom already answer on PM.
04-22-2018, 06:39 AM
RE: Bad / Possessed sd connct c4 or ?
I think your problem could be related to a cold joint solder, a bad trace in one of the SD Connect boards, a bad microcontroller or a relay.
If it is a relay, maybe when it is not connecting, try some light tapping on the SD Connect and see if it connects.
If you are using WIFI, try to switch to ethernet cable to see if improves, but I think it will not solve it.
If you think this post is useful or if it helped you, please press:
Reputation[Image: postbit_reputation.gif] and Thanks[Image: postbit_thx.gif] buttons bellow!!
 Thanks given by: DBmhh , i860
04-22-2018, 08:08 AM
I only used lan.
04-22-2018, 08:36 AM
(04-22-2018 08:08 AM)i860 Wrote:  I only used lan.
Just wondering, what vendor did you order the product from? Was it inexpensive or on the higher range of prices for SDConnects when you ordered it?
Like most participants on here, I volunteer my time to help others diagnose vehicles in their workshops and individuals alike. I appreciate greatly others that help me, and if I have helped you, please show your appreciation with the Thanks and Reputation button. Thanks!
04-22-2018, 08:42 AM
I bought the product from here:
https://www.aliexpress.com/item/S-Best-q...autifyAB=0
Mercedes Benz BAD ECU - Swap madwifi 7 485 07-31-2018 09:24 PM
Last Post: alevike
  W211 E55 AMG bad working on idle Tancho 15 1,304 05-02-2018 09:31 AM
Last Post: Mackhack
  Bad Map Update on a 2011 W212 4Matic mikeisfly 3 415 02-17-2018 01:54 PM
Last Post: mikeisfly
Mercedes Benz C4 sdconnect china bad clone or car problem Horstilein 6 844 05-23-2017 11:44 PM
Last Post: fabek
Mercedes Benz What if someone could repair bad MUX. 2007RennTechSL600 6 1,269 04-07-2016 09:29 PM
Last Post: Anturage
