Bmw e60 WinkFp update problem
12-15-2017, 01:38 PM
Car is bmw e60 2004
Hello everyone i tried to update SIM/SGM and ZGM with Winkfp over obd update wint fine BUT ACTIVE STEERING ERROR showed up, i recoded AFS no change, when i go to ncs expert to recode SGM/SIM or ZGM they are not there only ABG and i get an error when i try to default code it also i updated SFZ,SZL and i cant default code SZL i get an error and I dont see SFZ in ncs expert, i was going to update DSC and POW but before i did i went to check with ncs expert and they are not in there so i didnt WHY ARE THEY MISSING ? zna when i go to INPA/E60/Functional Jobs/UIF all off them are there. What needs to be done ?
No access to Icom and ISTA / P since i had to send it back for repair
12-15-2017, 02:36 PM (This post was last modified: 12-15-2017 02:37 PM by hojo29.)
RE: Bmw e60 WinkFp update problem
If you make SIM / SGM update also the system time must be restarted
And it must also be flashed the correct ZB numbers.
12-15-2017, 02:55 PM
I do know that system time needa to be reset via Tool32 problem is that in Ncs Expert when i hit Process Ecu there is no SGM there is only ABG and when i try to code abg i get an error, and i know that with Tool32 i should reset most likely sgm_60_2 with systemzeit_starten with 1 argument but it needs to be coded to default first
12-15-2017, 03:18 PM (This post was last modified: 12-15-2017 03:21 PM by hojo29.)
ABG is airbag !!!
With NCS you can see all the ECUs
Attached File(s) Thumbnail(s)
12-15-2017, 04:13 PM (This post was last modified: 12-15-2017 04:15 PM by Impac.)
Read what i wrote!!! And i know ABG is airbag, like i wrote in my first post SGM ecu is not in the Ncs Expert!!! And there is no DSC and no POW ecu’s also they are missing and i dont know why !!! Thats why i cant coded it, and thats why im asking for help because this is the first time something like that happened to me its all these modules show up in INPA in the UIF but not in Ncs Expert
12-15-2017, 04:24 PM
(12-15-2017 04:13 PM)Impac Wrote:  Read what i wrote!!! And i know ABG is airbag, like i wrote in my first post SGM ecu is not in the Ncs Expert!!! And there is no DSC and no POW ecu’s also they are missing and i dont know why !!! Thats why i cant coded it, and thats why im asking for help because this is the first time something like that happened to me its all these modules show up in INPA in the UIF but not in Ncs Expert
Send Team Login
BMW Get FSC into CCC E60/E61 Pogo 0 62 Yesterday 10:30 PM
Last Post: Pogo
  E60, Crank, no Start - only 5 Volts at Fuel Pump BigK 1 584 04-17-2018 10:17 AM
Last Post: kirukisu
BMW BMW E60 No Power on Ignition! gorrilaz2014 12 857 04-16-2018 03:08 PM
Last Post: gorrilaz2014
BMW BMW E60 ccc repair vlajko 98 232,630 04-16-2018 09:34 AM
Last Post: juht
  Any WinKFP EXPERTS HERE? gomarota 4 1,102 04-12-2018 09:23 PM
Last Post: Stelaras
