Latest news: --- please crash remove fiat panda 2011 --- Looking for Damos/Mappack for med17.5 Golf 6 GTi --- immo off sirius 32 - 8200046162 - s110030048 --- Audi A4 immo off --- C4 BSI Flash damaged ! 9658158780 --- Pincode --- Flash file --- Still need EDC17C46 EGR DPF OFF --- fiat panda 2011 year problem srs --- w164 how to shut teleaid message off on cluster --- FLASH REPAIR CITROEN C5 --- looking for 170 820 18 26 1D69J dump Mercedes R170 --- Audi tt mk1 apx engine "fuel and no spark" --- idle speed landcruiser --- Looking Damos/Mappack Audi MED 17.1.10 --- Help correct checksum edc17c42 --- Jaguar x-type 2.2 dpf off --- full bdm citroen c3 picasso 1.6hdi bosch 0281019819 --- vivaro 2.0cdti becoming a nightmare need immo off solution --- BMW E46 ME9 Virgin --- Passat 2.0 tdi siemens ppd dpf off --- Immo OFF KIA EDC17 --- Ford 6000 CD code need --- Reprogramming a new key for Nissan navara --- AIRBAG Benz GL320 2008 --- Passat CCM Pin code --- mmi 3gp us-->eu update straight to k0900? --- MS42 and EWS problem and cant start car --- Citroen Immo Off needed (Bosch ME 7.4.5) --- NEED IMMO OFF MEV17.4 PSA 0261201505 --- problem dashboard alfa romeo mito --- vw med17.5.2 immo off --- tcm vl381 flash need with odis --- FH I-Shift need help --- clear airbag peugeot 307 - siemens 9652712180 - 5WK42908 --- Mercedes PLD 07543 Repair help needed --- Vectra C pin code need --- BMW Navigation Update USB Road Map Europe MOVE 2018-1 --- immo off audi a3 me9.5.1 --- Gilera Nexus 500cm immo off - iaw15p.e4 --- Hyundai Pin code Required --- Galletto v54 hellp --- Fiat scudo 2013 2.0 HDI problem --- Map for Seat Navigation System MIB (AT) --- Please help pin code Becker BE7969 --- KESS software request --- Cat SIS 2011b question --- Easy connect Tomsad tool --- 206 GTI - Tight/Sticky Gearbox --- 206 GTI - Very Low Oil Temp ---
