  • 1 Votes - 5 Average
CLA W117 is it possible to deactivate PRE-SAFE?
09-20-2017, 02:12 AM
Hi guys. Can someone confirm that it is possible to deactivate PRE-SAFE in a W117 CLA? I have SD4 Xentry with DTS.
Thanks in advance.
A clever person solves a problem. A wise person avoids it.
Albert Einstein
09-20-2017, 05:22 AM
RE: CLA W117 is it possible to deactivate PRE-SAFE?
First you must made a scan with xentry. when you find the reason for pre safe in mosht cases with conducted (test in xentry) it will be possible to solve the problem. If car was involved in accident, with xentry reset module and accident data will be lost.
09-20-2017, 09:08 AM
PRE SAFE is standard in all Mercedes after I Think 2013 or 2014. You cant disable but why do you want to disable?
09-20-2017, 10:52 AM
yes possible
SA CODE ADD/REMOVE ,SEED KEY , ADBLUE DPF OFF , VMAX, SCN coding, pin code radio
XENTRY 07.2018 INSTALL C4 , LAMP RETROFIT LED
Skype grajek41
09-20-2017, 11:49 AM (This post was last modified: 09-20-2017 11:58 AM by joker205.)
(09-20-2017 09:08 AM)Dumper Wrote:  PRE SAFE is standard in all Mercedes after I Think 2013 or 2014. You cant disable but why do you want to disable?
Customer would like to have it decoded because the radar is missing together with wiring after
being crashed. Sadsmile
Albert Einstein
09-20-2017, 12:43 PM
never tried, but check samf, cgw, IC
09-20-2017, 01:06 PM
I have now related fault codes appearing in ESP and EZS. From IC decoded no problem with Xentry dev.
Albert Einstein
09-20-2017, 07:34 PM
Use vediamo or DTS Monaco.
I donĀ“t think that Xentry dev will give you the needed possibilities to deactivate the pre safe feature.
09-20-2017, 09:46 PM
Can you share for us what gives you short test after scan in xentry?
Will be much better to say something about it.
Maybe its time to take someboty else to do this job?
  No Map Update possible NTG 4.7 realinfoman 4 557 07-01-2018 11:14 PM
Last Post: realinfoman
  reset ecu CLA 220D delphi crd3.E1 valkyr1e 5 401 06-29-2018 02:27 AM
Last Post: tirex2k
  w117 cla usa to eu rear lamp coding robotukas 3 416 06-14-2018 11:08 AM
Last Post: jkiller1983
Mercedes Benz W222/C217 facelift steering wheel in pre facelift retrofit Merza87 8 852 06-02-2018 09:46 PM
Last Post: rashid
Mercedes Benz Need Vediamo coding save file 2016 pre facelift CLA45AMG skull1 4 511 05-14-2018 01:18 PM
Last Post: skull1
