Cant connect to PTCM ?
08-10-2018, 02:41 AM
Mercedes Benz Cant connect to PTCM ?
Hey all
I have a problem that i cant connect to my W221 PTCM ecu in vediamo ?
I Can fine connect to others ecu
But when i try connect to PTCM i get the:
Error:Unable to establish communiacation with ecu reason CAESAR:ChannelManager:03039:ecu responded with a refuse message to the init message.
What im i doing wrong here since i cannot initiate contact whit the ecu ?
08-10-2018, 03:20 AM
RE: Cant connect to PTCM ?
It may not have one depending on the year
________________________________________________________________________________​​______
08-10-2018, 03:27 AM
Right connection speed set? Don't know if this ecu also needs change.
08-10-2018, 03:56 AM
The car is from 11-2007 and has automatic tail gate and whit buttom to close tailgate
I Will code it so i Can close whit key
How Can i see if it has the PTCM ECU ?
08-10-2018, 06:38 AM
probably not right cbf or ignition off
08-10-2018, 07:39 AM
Hey Tirex2k and thanks for reply
is there any way to tell if my cbf is bad ?
do you mean i should connect whit ignition off ? og only tried whit ignition on and whit car startet to acces the PTCM but no luck
08-10-2018, 07:54 AM
No u need ign on and use right cbf. Also i dont remember if its can or kline, for kline u need vedi 4.02.02
08-10-2018, 08:20 AM
ok i have igen on and also tried whit car startet but no lock
How can i attached pictures ind this forum ? or file
here is picture from PTCM today whit the error https://imgur.com/a/sh2f2pn
08-10-2018, 12:40 PM
Are you trying to code the trunk? That has nothing to do with the PTCU.. This car does NOT have a PTCU.. PowerTrainControlUnit is on the engine CAN and other CANs involved in Radar systems ect. not interior CAN, and a 2007 w221 did NOT have a PTCU
I think your terminology is a bit off....
 Thanks given by: HestonDiag
Mercedes Benz SD connect C4 problem msr 1 268 08-05-2018 07:16 AM
Last Post: LORD
  Xentry Kit | Kit 2 | Connect BD 03-04/2018 hayk57 7 1,390 08-01-2018 09:43 AM
Last Post: Azzatec
Mercedes Benz SD Connect C4 -- avoiding garbage s65amg 186 23,005 07-31-2018 06:03 AM
Last Post: bachirnassif
  China SD connect's guide sryang86 278 84,796 07-30-2018 10:55 AM
Last Post: DonCamillo
Mercedes Benz help me connect SD Connect 4 with lan cable kentrinite 13 960 07-15-2018 06:59 AM
Last Post: LORD
