  • 1 Votes - 2 Average
Chevrolet Captiva ECU-Flash error - Motor doesn't start
08-12-2017, 09:56 AM (This post was last modified: 08-12-2017 10:06 AM by Xxtreme.)
Chery Chevrolet Captiva ECU-Flash error - Motor doesn't start
Hi members,
i have a big problem, I tried to flash my Captiva. I plugged in the ODB.
- Read the ECU
- started the flash of the new file
After one second MPPS v13 checked the cheksum and the lights of the car turns on.
After this the Software shows an error. Now i can't read/write/access the ECU.
Every time 'Error'
The motor doesn't start. Lights/Air etc are working....
I plugged the Battery off now...
PLS GIVE TIPS! WHAT CAN I DO NOW??? Is my ECU bricked now?? it's a EDC16C39 ECU
08-12-2017, 10:22 AM
RE: Chevrolet Captiva ECU-Flash error - Motor doesn't start
the same problem can happen with galletto... Now You need to read it on the table by BDM and post here the file also you need to write ecu numbers , dont worry eeprom will be ok.
08-12-2017, 10:44 AM
make recovery....
set write speed to low..
write original file..
 Thanks given by: Xxtreme
08-12-2017, 10:55 AM
yes, recovery made this !! THX Aleksey.diag
08-12-2017, 10:58 AM
did you chksum the file your writing ?, did you use dpf/egr pro acs
08-12-2017, 11:22 AM (This post was last modified: 08-12-2017 11:23 AM by Xxtreme.)
yes chk is ok, and the problem is solved, recover mode is working
egr off and chiptuning file, Chk make mpps self
  sprinter 2001 start error problem/0281010618 parvanov3 1 91 08-11-2017 08:34 AM
Last Post: mb_port
Chevrolet Chevrolet Captiva EGR off please help Xxtreme 6 161 08-08-2017 11:52 AM
Last Post: Xxtreme
Renult Renault ECU why don't start?: rudy102 2 128 08-08-2017 03:46 AM
Last Post: alfabit
Chevrolet Digiprog 3 Chevrolet Camaro 2012 Bob the builder 1 129 08-07-2017 10:44 PM
Last Post: Bob the builder
  pin code Chevrolet Sonic2017 saadiadel 0 115 08-06-2017 03:58 AM
Last Post: saadiadel
  recommend best Chinese tool for motor bike key programming tool HIGH TECH AUTO 0 119 08-04-2017 11:41 PM
Last Post: HIGH TECH AUTO
Chevrolet Alarm Gm CHevrolet S10 93C46 Pin ? Fernandowap 3 135 07-31-2017 04:10 AM
Last Post: Fernandowap
  Chevrolet spark 2011 dash Sanchos 4 136 07-25-2017 03:41 AM
Last Post: Sanchos
  Mercedes Vito 2001 Start error help . Lucian Mc 9 673 07-25-2017 12:41 AM
Last Post: bueanasuerte
Chevrolet 2014 Chevrolet Agile / utilty bakkie dash rtbdiagnostic 2 138 07-21-2017 05:40 AM
Last Post: KriyenKPp
