Citroen C4 2,0 HDI P0088
08-20-2017, 05:52 AM
Hello
I have a problem with one C4 2,0 HDI 136 HP 2005 year:
When i accelerate after 3000 rpm the car gives error P0088 !
Please help with any solution!?
Thanks in advance
If you like my post and it helped you please press THANKS and +1 Reputation !Smile
08-20-2017, 05:53 AM
RE: Citroen C4 2,0 HDI P0088
Injectors, pressure regulator, pressure sensor, wiring, ecu....
If my post help you click [Image: postbit_reputation.gif] and [Image: postbit_thx.gif]
Live, brothers, with luck and do not hate those who hate us.
 Thanks given by: rosi1000rr
normally bad tune / remap can do that , is it original ?
08-20-2017, 06:01 AM (This post was last modified: 08-20-2017 06:02 AM by rosi1000rr.)
Was DPFoff but No tuned... is possible anything wrong with the flash!?
(08-20-2017 05:53 AM)Artifact Wrote:  Injectors, pressure regulator, pressure sensor, wiring, ecu....
Already check all mate without success...
08-20-2017, 06:47 AM
if original ok when yes bad file
08-31-2017, 02:15 PM
(08-20-2017 06:47 AM)@[email protected] Wrote:  if original ok when yes bad file
Solved
Was bad file!
Thank you for the help
  Citroen Xsara 1.6 HDI Crank No start - Fans ON jaxone 7 336 06-01-2017 09:47 AM
Last Post: Vish
Citroen citroen c6 2.7 hdi or peugeot 607 jaguar s type 2.7 hdi v6 beniopyt 5 422 05-10-2017 04:13 AM
Last Post: P2XA
  Citroen C3 1.4 HDI EDC17C10 IMMO PROBLEM robertos2000 0 206 04-04-2017 07:38 AM
Last Post: robertos2000
  Citroen c4 picasso hdi egr issue siailis 5 863 01-18-2017 02:52 AM
Last Post: fusher
Citroen [SOLVED] Citroen C5 1.6 E-Hdi Auto Transmission need help. Cretarus 1 420 07-23-2016 12:12 AM
Last Post: reystos
  Citroen C4 1.6 hdi no communication? marctok 5 722 06-02-2016 08:51 AM
Last Post: obd.tech
Citroen 2012 Citroen Jumper 2.2 HDI 130 Euro 5 - DPF removal? oeriberg 11 2,377 05-31-2016 09:35 AM
Last Post: oeriberg
Citroen citroen berlingo 1,6 hdi don`t start ( edc16c34 ) anchri 6 915 03-22-2016 03:10 PM
Last Post: diagnostix
  citroen xara picasso hdi wiring diagram gs_el 3 756 02-12-2016 11:59 PM
Last Post: gs_el
Citroen citroen dispatch 2.0 hdi ECU virgin or immo off maki8 1 501 01-18-2016 04:22 AM
Last Post: diimon
