  • 32 Votes - 2.75 Average
Citroen Xsara PIcasso 2005 Siemens BSI EEprom 95160 dump HELP
08-19-2013, 08:42 PM
Citroen Citroen Xsara PIcasso 2005 Siemens BSI EEprom 95160 dump HELP
Dear all
I have a strange problem with my Xsara Picasso 2.0 HDI from 2005.
After mileage correction I am not able to see ECU and there are several errors in the BSI. It is siemens BSI with 95160 EEPROM. I have check all wires and fuses. I have used Lexia to enter PIN code and made BSI configuaration.
The car can start and all equipment and functions work fine and when you drive you do not feel any problem but when you switch ignitions and after about 10 minutes the car cannot start.
All BSI configuration , VIN , and PIN is not memorized any more and you need to do BSI configuration again.
I have configured it several times but it always disappear after 10 minutes after the ignition is switched off.
I have attached EEPROM dump. maybe there is somthing wrong with it.
Do any of you have any idea what I could do?
Thank you in advance
08-19-2013, 08:56 PM
RE: Citroen Xsara PIcasso 2005 Siemens BSI EEprom 95160 dump HELP
So I went to c5.
Starter motor was shorted.They were full of clutch dust
 Thanks given by: webmaster
08-19-2013, 09:17 PM
(08-19-2013 08:56 PM)gery0627 Wrote:  So I went to c5.
Hi
I am not sure if I understand this.
Could you pls. explain how this is related to my problem?
09-03-2013, 05:27 AM
While you placed 95160? Please upload the dump I will check it for errors
Regards Cristian
06-27-2014, 08:07 AM
hi friends i have a similar problem.
siemens bsi, xara picasso
95160 dump, seems any problem with.
any virgin file? i must change the vin in the virgin file?
thanks for helping.
Attached File(s)
ori_95160.zip
File Type: .zip
Downloaded: 57 times
06-27-2014, 07:19 PM
Any virgin dump????
07-21-2014, 07:04 PM
Solved
Citroen C4 picasso 2008 edc16c34 SERVICE HISTORY Gregforce 2 71 Yesterday 08:38 AM
Last Post: Gregforce
Citroen Citroen C4 Picasso II Crash DATA MTW 0 87 Yesterday 07:14 AM
Last Post: MTW
Citroen Citroen C4 Picasso 2014 - ( BSI 95256 ) Need mileage to be corrected m37h0d 0 57 05-24-2017 04:40 AM
Last Post: m37h0d
  citroen xsara bsi virgin Keyproffs 9 169 05-23-2017 12:57 PM
Last Post: Keyproffs
  please need virgin BSI P307 95160 autogaz1984 6 95 05-23-2017 12:47 PM
Last Post: GORTUNE
Citroen Xsara hdi110 immo off 0281010962 edc15c2 chipfuse 3 64 05-21-2017 11:39 PM
Last Post: elas00
Dacia SRS Continental 8201 163304 Dacia Duster 2011 95160 ermuraky1 2 54 05-20-2017 06:29 AM
Last Post: rafal.gt
  citroen c5 sagem bsi xipsilon 5 76 05-19-2017 04:18 AM
Last Post: xipsilon
Citroen C4 correction dash and BSI dump konrad199915.98 2 73 05-18-2017 02:50 AM
Last Post: konrad199915.98
  Citroen C4 Picasso mileage correction tbugla 7 196 05-17-2017 01:18 PM
Last Post: tbugla
