  • 7 Votes - 3.57 Average
DPF EGR Lambda Remover 2017.05
08-12-2017, 09:21 PM (This post was last modified: 08-12-2017 09:23 PM by kicio.)
Tested on car
tiguan vw 2.0 tdi dpf off edc17cp14 dosent worked
opel insignia 2.0 cdti edc17c11 dosent worked dpf off
vw passat 2.0 tdi ppd 1.2 siemens hot start + egr off worked
1.6 TDI siemens PCR 2.1 dpf off worked
Rauch15
 Thanks given by: HeXeN
08-12-2017, 10:10 PM
RE: DPF EGR Lambda Remover 2017.05
did you check in files that you say is working too see how many errors is deleted? Smile
REMAP+100% working manualy solutions dpf-egr-vsa-nox-scr...etc
Genuine WinOLS
Skype: aemtuning
08-12-2017, 11:16 PM (This post was last modified: 08-13-2017 06:58 AM by @batterypack@.)
its not worth the computer space its taking up , your reputation is worth more than returning customers complaining
 Thanks given by: razor1199 , aemtuning , teme69 , norman1967
08-13-2017, 08:10 AM
that is result of free soft Smile perfect work with winols.
Tuning Stage1 / Stage 2, DPF, EGR, DTC, all immo, airbag clear crash...100% Winols Genuine Working solutions
DONT FORGET THANK'S AND REPUTATION
Skype: tiarty
08-13-2017, 09:08 AM
(08-13-2017 08:10 AM)krimo Wrote:  that is result of free soft Smile perfect work with winols.
you know this is ASC, 1k € software, right?
ecudecoder.com
and yes, I've made comparisions between ORI and cracked...
 Thanks given by: norman1967
08-13-2017, 10:21 AM
ecudecoder.com
Hello please advise further on your comparison
Do you think the cracked works as good? Or has bugs?
Or is the €1000 program just as bad as the cracked?
08-13-2017, 10:24 AM
is the same bad program and is not 1000e
Genuine WinOLS
Skype: aemtuning
08-13-2017, 10:29 AM
Most solutions are identical. of course with original you have support, updates, and so on...
(08-13-2017 10:24 AM)aemtuning Wrote:  is the same bad program and is not 1000e
you are free to try buying it from the website..
[Image: koiaQ9Y.jpg]
08-13-2017, 09:23 PM
Opel EDC 16 dpf and egr off working well
VW Group EDC 16 dpf off working well, but better use switch (1 bit switch)
  v2017.05 Professional DPF-EGR-Lambda-Adblue-Flap-Remover For MHH Members! IMMO-KILER 836 39,059 Today 07:01 AM
Last Post: mouaoued
  MTX DTC Remover 1.8.5.0 Keygen+Soft fantomel 40 5,034 Yesterday 08:31 AM
Last Post: kirukisu
  BMW 325i E36 Bosch motronic 403/405 lambda off Gaijin 0 85 08-19-2017 09:25 PM
Last Post: Gaijin
  Activation v2017.05 Professional DPF-EGR-Lambda-Adblue-Flap-Remover Tim1313 120 3,913 08-16-2017 09:14 AM
Last Post: diagnostix
  DPF EGR Lambda Remover 2017.05 Keygen + Kits fantomel 31 4,661 08-16-2017 08:42 AM
Last Post: seva
  DPF EGR Remover V3.0 - 2016 Keygen+Soft fantomel 14 2,223 08-16-2017 06:13 AM
Last Post: seva
Mercedes Benz w220 disable lambda need open loop mardock2009 2 217 08-15-2017 04:25 AM
Last Post: builes13
  Mini one R50 1.6 lambda off HEYAH 2 175 08-09-2017 09:28 AM
Last Post: DPF-OFF
  lambda callo 3 157 08-05-2017 02:51 PM
Last Post: mansens198803
Audi Audi TT 3.2 Lambda OFF Hyphonics 3 132 08-05-2017 06:44 AM
Last Post: aemtuning
