DPF off or not ?
01-11-2017, 12:38 PM
DPF off or not ?
I have a file here, I only want to know if DPF is off in the file or not. Please, all you Pro`s, take a look at the file and tell here.
T5 394112.zip
File Type: .zip
Downloaded: 12 times
01-11-2017, 02:57 PM (This post was last modified: 01-11-2017 03:07 PM by lsdlsd88.)
RE: DPF off or not ?
It is indeed a tuned file (with some arguable choices XD), and they changed a switch at 0x1D5934, I have no idea what it does.
Here your ORI.
EDIT: it's "Schalter- Wert, um die EGT- Funktionen ein- oder auszuschalten" "Switch value to turn the EGT functions on or off" so I guess it's ok?
Attached File(s)
VW_Bus_T5_TDI_2004_Turbodiesel___128KWKW_Bosch_Bosch_070906016EA_394112.zip
File Type: .zip
Downloaded: 9 times
 Thanks given by: Boosthead
01-11-2017, 10:39 PM
Thank you very much. EGT= Exhaust Gas Temperature. I can`t see any
temperatures and pressures of DPF with this tuned file in car.
I think, it`s DPF off file.
01-11-2017, 10:49 PM
(01-11-2017 12:38 PM)Boosthead Wrote:  I have a file here, I only want to know if DPF is off in the file or not. Please, all you Pro`s, take a look at the file and tell here.
the file is already tuned and 1 of the switch is off but not is full
  Citroen C4 DCM3.5 Dpf and dpf liquid pump off MKS_1 9 457 10-24-2016 09:46 AM
Last Post: dychtan
Ford Please DPF off and DTC dpf off simon32 4 973 06-13-2016 11:49 AM
Last Post: bodzio012
  Please check this files SPRINTER-906-DCM3 DPF ON / DPF OFF GMXcool 1 670 04-15-2016 03:17 AM
Last Post: mike_service
  dpf off egr off lambda off dtc off DIAGMECA 2 1,496 11-27-2015 01:27 AM
Last Post: motorsportsz
  AUDI A4 2006 2.0 DPF off not working..! kaToo 19 3,458 02-28-2015 06:18 PM
Last Post: melcool
Opel Zafira will not start after DPF remove urimi2 6 904 02-13-2015 11:55 PM
Last Post: Dennis-
