  • 29 Votes - 2.45 Average
DPF remove
02-22-2013, 01:05 PM
VW DPF remove
Hello can anyone reliably remove the DPF?
Please do not use ECU safe, volta. Did I own.
Thank you very much
Attached File(s)
WinOLS (VW Passat ( tun neu ohne Anpassung) - 372127).rar
File Type: .rar
Downloaded: 100 times
 Thanks given by: gojko , quyet0301
02-22-2013, 10:04 PM (This post was last modified: 02-22-2013 10:08 PM by cocoliso309.)
Mercedes Benz RE: DPF remove
(02-22-2013 01:05 PM)kreschak Wrote:  Hello can anyone reliably remove the DPF?
Thank you very much
Thank you very much
you have to remove filter and set to 0% with vagcom
Attached File(s)
volta.zip
File Type: .zip
Downloaded: 140 times
 Thanks given by: antonik , quyet0301
02-23-2013, 05:10 AM
RE: DPF remove
kreshack says "don't use ecusafe or volta"
this file is made with volta... Big Grin
if you need contact for manual solution
Ecu tuning, DPF, EGR and FLAP remove
02-23-2013, 05:47 AM
RE: DPF remove
Thank you, I sent the file to my programmer.
DPF is removed manually.
Thank you anyway.
Thead please closed
Opel Zafira DPF/EGR Remove gordontwist 1 120 08-18-2017 02:23 AM
Last Post: afrpowersolution
  pls remove dpf bmw e90 330D edc16C35 mplinux 2 107 08-05-2017 04:52 AM
Last Post: mplinux
  Need remove dpf, egr and flaps 028101445 Vectra C 1987robson 3 811 06-22-2017 07:11 AM
Last Post: powertothepeople
  Audi A3 03G906018DH Siemens PPD1.2 remove DPF abbassi.diag 1 270 05-31-2017 06:00 AM
Last Post: jPPerformance
Opel Opel Zafire remove DPF deadmaroz-tlotl 8 391 05-30-2017 11:51 PM
Last Post: donesko
  Dpf faults remove Jamesd2017 1 259 05-24-2017 12:24 AM
Last Post: mike_service
Renult help to remove dpf for renault kangoo with dcm3.4 alloh81 1 333 05-07-2017 02:55 AM
Last Post: barek2009
  Solution for remove DPF - EGR - SWIRL FLAP mariusica_boy 20 10,927 05-04-2017 10:41 AM
Last Post: mb electronic
Mercedes Benz MB 220 CDI DCM3.2 DPF Remove roubinios 3 315 05-02-2017 11:02 AM
Last Post: krimo
  remove DPF and EGR on Nissan NV200 1.5dci euro5 20O9 guidotacco 6 375 05-01-2017 10:22 AM
Last Post: guidotacco
