  • 11 Votes - 3.91 Average
DTS and Toolkit problem
09-20-2017, 10:04 AM
I have Xentry, Vediamo and DTS installed. So, after installing dts, toolkit stops working. When I start toolkit I receive error 802, 891. I tried to copy toolkit from Xentry to dts, and installing new SDconnect, but it doesn’t work. If I install SDconnect it won’t start (nothing happend), when I start toolkit from Xentry, it start and I receive error 802 or 891. Any idea?
BMW Coding Programming Retrofitting
Mercedes Benz Coding Retrofitting
Online help by TeamViewer
CID Changeable SD cards! 100% working!
09-20-2017, 11:05 AM
RE: DTS and Toolkit problem
Here you go..
http://mhhauto.com/Thread-DTS-Monaco-How...ke-it-work
If my post was helpful, +thanks +rep Tup
 Thanks given by: temo4ka
09-20-2017, 12:45 PM
(09-20-2017 11:05 AM)Johnplus Wrote:  Here you go..
Doesn’t work
09-20-2017, 03:35 PM
Copy the files in the C:\Program Files (x86)\Mercedes-Benz\SDConnect Toolkit folder
Replace the folder into the C:\Program Files (x86)\Softing\Diagnostic Tool Set 8\8.03\Interfaces\DCDI_DPduApi\eCOM_Toolkit
09-20-2017, 07:58 PM
(09-20-2017 03:35 PM)engine Wrote:  Copy the files in the C:\Program Files (x86)\Mercedes-Benz\SDConnect Toolkit folder
Nothing starts on startup. If I manually try to start TkTtay in DTS, nothing happens. So your solution doesnt work Sweating where are logs for toolkit? Maybe in logs I can find something.
09-20-2017, 09:05 PM (This post was last modified: 09-20-2017 09:08 PM by Jake5555.)
I think you have maybe more mistakes in your install than you think.
You need to check it step by step:
Before starting anything like Xentry/vediamo/DTS.
- Do you have a Connection Symbol in the task bar when you connect your C4 by lan?
- Does the toolkit recognize your C4?
- Is the IP and subnet mask correctly set in the toolkit?
- Does Xentry work with your C4? License set? Quicktest?
- Vediamo is recognizing your C4 as well?
Answering one question with NO you need to solve this problem first.
If you are able to answer all these questions with yes you may try to solve your problem with DTS. Which means that you need to configure your DTS then correctly. This is explained in temo4ka thread. See posted link by Johnplus.
Good luck.
09-20-2017, 09:21 PM
Good luck.
On each question I can answer with “No”, but if toolkit won’t work then I can’t connect with Xentry to car, can I? I can start DTS, problem is I can’t start SDconnect toolkit.
09-20-2017, 09:29 PM
Good luck.
And again STEP-by-STEP.
Forget for the moment about Vediamo or DTS!!!
Before you install Vediamo and DTS
--> Did toolkit work?
--> Did Xentry work?
--> License for Xentry installed?
--> Xentry quicktest performed?
Get these Points/topics work first without the other programs installed. And then you may try further installs.
Vediamo should even work after a install after xentry.
And for DTS you Need to do the workaround described in the link.
At the moment nobody may help you cause nobody nows at which moment it does not work anymore?
09-20-2017, 09:53 PM
I didn’t test it, so better to reinstall Windows and install again or uninstall dts? Win 7 64 bit is good for Centry, DTS and Vediamo? I had installed 7 x86.
Mercedes Benz DTS 8 MONACO HOW TO DO VARIANT CODING FOR DVD LOCK FREE(VIDEO IN MOTION)? likemovie 28 4,584 07-14-2018 10:45 AM
Last Post: Ilja
Mercedes Benz DTS Monaco8.3.12 FREE Activations for MHHAuto Members! wangtianlong 728 160,546 07-13-2018 09:06 AM
Last Post: beckereurope
Mercedes Benz DTS Monaco. How to make it work. temo4ka 26 15,104 07-08-2018 09:38 AM
Last Post: A2ua
Mercedes Benz DTS database wangtianlong 41 19,500 07-03-2018 07:44 AM
Last Post: Camillo85
  Vediamo or DTS to change vin in electric steering tferrari 18 1,612 06-29-2018 01:51 AM
Last Post: Vitalyr133
