  • 1 Votes - 3 Average
Different hardware MIB2 versions Q7 4M?
09-20-2017, 12:19 AM
Just wondering whether anyone knows the difference between these two Q7 4M MIB2 "HIGH" versions.
4M0 035 035
4M0 035 041
From the two cars I have compared, they both have Virtual Cockpit, bluetooth, surround cameras, front A5 camera, DAB radio. All the connectors are the same on the rear of both units.
The only thing that is different in the 4M0 035 041 has "active sound" system with amplifier in the MIB2 while the 4M0 035 035 uses "BOSE" with separate amplifier in the rear. Looking at the dataset's between the two from VCDS they are different (but both have been updated to SW 976):
Address 5F: Information Electr.
Control Module Part Number: 4M0 035 035 G
Component and/or Version: MU-P-LND-EU 050 0976 <<<<
Software Coding: 013706010000000013111102000A00332F001BE701700100BE
Work Shop Code: WSC 00046
VCID: 281C34AD5335CA0764-807C
Advanced Identification/FAZIT
Serial number:
Identification: JTB-074
Date: 05.08.15
Manufacturer number: 1182
Test stand number: 0E0C
Flash Status
Programming Attempts(application): 0/8
Programming Attempts(data): 65535/1/2
Successful Attempts(data): 65535/1/2
Flash Date: 00.01.01
Flash Tool Code(data): 61029 123 12345
Misc.
Hardware number: 4M0 035 035 A <<<<<<
Workshop System Name: J794
Equipment/PR Code: 00000002E43D608C
Dataset Number: 4M0909545C <<<<<<<
Dataset Version: 0023 <<<<<<<
ASAM Dataset: EV_MUHig6C3Gen2HBAS
ASAM Dataset Revision: 001115
Control Module Part Number: 4M0 035 041 G
Component and/or Version: MU-P-LND-RW 051 0976<<<<<<
Software Coding: 01370608FF0A000013511101000A00332F001BE601700104FE
Work Shop Code: WSC 12345
VCID: 25023E9224AD7969BA-8070
Serial number:
Date: 10.11.15
Manufacturer number: 1192
Test stand number: 09BA
Flash Status
Programming Attempts(application): 0/4
Programming Attempts(data): 65535/1/8
Successful Attempts(data): 65535/1/8
Misc.
Hardware number: 4M0 035 041 A <<<<<<<
Equipment/PR Code: 000000021571CF5D
Dataset Number: 4M0909545D <<<<<<<
Dataset Version: 0029 <<<<<<<
09-20-2017, 07:49 AM
RE: Different hardware MIB2 versions Q7 4M?
The component version is different the 35 is EU European and the 41 is RW Rest of the World. There might be differences in the radio frequencies.
09-20-2017, 03:41 PM
I understand
Thank you for your help
VW MIB2 vcp login The_Bodger 2 250 08-28-2017 02:07 AM
Last Post: The_Bodger
  MIB2 5F MQB Adaption Security Access code? spyderboyant 5 1,026 08-18-2017 01:56 PM
Last Post: kamold
VW MIB2 EEPROM edit Adam87 10 634 08-16-2017 12:43 AM
Last Post: realtek
VW Passat CC which hardware for 03L906018BH? edo99 2 202 04-04-2017 08:53 PM
Last Post: edo99
  Mib2 USB connector wiring kamold 2 412 03-22-2017 08:06 PM
Last Post: kamold
VW MIB2 RETROFIT ISSUES HELP GTIED25 7 590 03-22-2017 01:59 PM
Last Post: safm
  SGO file versions l0x2 5 848 09-05-2016 07:11 PM
Last Post: acmotor
VW [Retrofit MIB1 to MIB2 - MK7] Park Pilot(OPS) and Rear Cam doesn't work aqxavier 0 1,497 11-06-2015 02:01 AM
Last Post: aqxavier
Audi Q7 MMI 3G+ upgrade - different MMI Units? spyderboyant 0 1,311 06-14-2015 01:23 AM
Last Post: spyderboyant
VW Vag Tacho 1.7, 2.2, 2.5, 3.01 versions digital4 10 11,317 03-02-2015 01:15 AM
Last Post: muki461
