Disabling EGR on CDI
06-13-2018, 11:48 PM
Mercedes Benz Disabling EGR on CDI
Hi Everybody,
Another question:i ve nothing against DPF or CAT BUT i really don't like EGR. Exhaust gas should not be used as fresh air for an engine :o)
I would like if it is possible to disable EGR without removing the system. Can someone tell how, or explain or share?
Any advice would be appreciate ;o)
Thanks mates
06-14-2018, 12:44 AM
RE: Disabling EGR on CDI
you can disable egr from ecu software.for this you need to read ecu first then mod file and write back.
REMAP/DPF/EGR/SCR/LAMBDA...cars/buses/agriculture
Skype: aemtuning
dont ask for free files
sgo/frf bin converter
 Thanks given by: RHA057
06-14-2018, 03:05 AM
what type cdi?
year?
cc?
06-14-2018, 03:57 AM (This post was last modified: 06-14-2018 03:58 AM by RHA057.)
A 265hp 350cdi 2013 R-Class 4matic long
@aemtuning is it possible with vediamo or a mercedes tool or software?
06-14-2018, 04:21 AM
if you disable the egr, doesn't this require any hardware modification?
06-14-2018, 04:25 AM
i read you can disable it by ecu flash and no need to remove something
06-14-2018, 04:36 AM
just asking as you also can disable by software DPF, but I don't think it makes sense to disable it without any hardware modification.
06-14-2018, 05:13 AM
I can remove the system but every two years here in France, each car has to be controlled by a special technical center and the car has to be like a stock one. My dad on his van ,he uses it to go to carry stuff, so he removed his back seat (removable) . He had to put back the back seat (a lot of back word) to get the agreement.
400 check points on each car now. It s crazy.
06-14-2018, 08:57 AM
(06-14-2018 05:13 AM)RHA057 Wrote:  I can remove the system but every two years here in France, each car has to be controlled by a special technical center and the car has to be like a stock one. My dad on his van ,he uses it to go to carry stuff, so he removed his back seat (removable) . He had to put back the back seat (a lot of back word) to get the agreement.
True some here in Belgium but still, what's the point of disabling something if you still require modification. Ok, if you are willing to do the modification, you can adjust on the w212 without any problem with vediamo. But I'm not sure if it is require to do the hardware modification or not for dpf and / or egr.
Maybe someone who is more skilled on automotive technologies than me can answer this...
Mercedes Benz Start/Stop code off in X117 CLA 220 cdi 4matic m.y.2016 doctorcico 6 848 08-14-2018 08:54 PM
Last Post: minogun
  MB W204 C200 CDI saws at idle speed autobirotula 4 386 08-14-2018 07:19 AM
Last Post: autobirotula
  W906 Sprinter CDI read problem sparehellas 8 435 08-10-2018 03:22 AM
Last Post: cool24
Mercedes Benz Mercedes W211 E270 cdi 2003 battery problems please help???? 4life211 16 1,050 08-03-2018 02:37 AM
Last Post: Mercerwin
  Really stuck need help: W211 E320 CDI fault 2510-001 laz79 30 1,561 07-25-2018 12:54 AM
Last Post: laz79
