  • 1 Votes - 5 Average
Dpf removal
01-22-2018, 01:48 PM
Dpf removal
Hi all
How can I check if dpf has been disabled in ecu?
Do I need special cable to read dde?
01-22-2018, 01:54 PM
RE: Dpf removal
What vehicle is it mate?
If I help, Thanks and Rep is appreciated : fing32: :sonrojo: this forum is awesome
01-22-2018, 01:55 PM (This post was last modified: 01-22-2018 01:56 PM by b21playa.)
RE: Dpf removal
(01-22-2018 01:54 PM)lopez_osmin690 Wrote:  What vehicle is it mate?
E90 335d
I want to update dde but not if dpf has been disabled
01-22-2018, 02:11 PM
RE: Dpf removal
read errors
If i helped please use thanks+rep buttons Smile
01-22-2018, 02:12 PM
RE: Dpf removal
Look for ash and soot content. They must be 0 if disabled.
01-22-2018, 02:17 PM (This post was last modified: 01-22-2018 02:18 PM by b21playa.)
RE: Dpf removal
(01-22-2018 02:11 PM)kcity Wrote:  read errors
Only errors are glow plugs
(01-22-2018 02:12 PM)Ddnc Wrote:  Look for ash and soot content. They must be 0 if disabled.
Is there an option for this in ista/d?
01-23-2018, 12:41 AM
RE: Dpf removal
For what reading errors? when someone tourn it off good, then it will never be some errors.
Ista d can show you in parameters when and or it will need to burn the DPF but somtimes also not showing you. Everything is depends of how someone did it.
The best solution is to read the ecu (Ktag, kess or something) and check the maps.
01-23-2018, 01:27 AM
RE: Dpf removal
there is a old saying "if its not broke, don't fix it"
if your updating dde because you can and for no other reason I would advise you not to
049
thanks and reps go a long way!
Beer
01-23-2018, 06:16 AM
RE: Dpf removal
Can 't point you in to the exact place but it's DPF live stream data. Totally agree with 4ly-syk
  Japanese cars - "ETC card not inserted" removal of this nag Willisodhiambo 0 958 11-30-2017 10:47 PM
Last Post: Willisodhiambo
BMW BMW MSV70 vehicle speed limitation removal dezibel 2 1,154 08-12-2016 10:22 AM
Last Post: ppm007
BMW F30 Towing hook removal coding craciunaero 0 549 03-19-2015 11:41 AM
Last Post: craciunaero
2 Guest(s)
