[E90] 330xD -asking for consultation in the interpretation of errors
12-12-2017, 07:43 AM
BMW [E90] 330xD -asking for consultation in the interpretation of errors
I understand what errors are showing up,
but it's always worth it and it's nice to consult
(the last three are not important)
[Image: 330xd_errors.jpg]
if you don't look back at your car after you park it, you own the wrong car
41(always help)
12-12-2017, 07:51 AM
RE: [E90] 330xD -asking for consultation in the interpretation of errors
Faulty glow plugs or glow module, due this dpf may not be regenerated. Check backpressure sensor after first things sorted.
 Thanks given by: jacek.marciuk
12-12-2017, 10:22 AM
You have an error of extremely high pressure dpf. it is very clogged. Must use Inpa, choose the engine, read the errors and the way. During driving, the error F2 must be deleted. Perhaps the filter will go through the regeneration state. If fault 0481a does not appear anymore, you must use ista and enable filter regeneration in the service function
Ja te┼╝ z Polski.
REP+ THX NeedThankyou
12-12-2017, 11:01 AM (This post was last modified: 12-12-2017 11:02 AM by larshutten.)
First run a DPF back pressure test to see how bad it is BE AWARE, if the back pressure is way to high at iddle and 2000rpm don't rev it to 4-5k rpm. After that you have to fix your glow plug issue(module and/or plugs). Clear errors and make sure the engine reaches about 75-80 degrees. Under service functions you can activate regeneration, there is explained how to drive the car and what values are needed before it get's activated. If you are lucky after this drive the back pressure drops to normal values.
Edit,
About your VTG, change oil and reset the values under service functions.
12-12-2017, 01:06 PM
DPF values can be read out with ISTA / D.
12-12-2017, 01:21 PM
All BM's will not regen with any fault codes in system test glow plugs in situ with direct live wire to battery if all the faulty ones are sparking when splashed with power ie (not open circuit) then controller more likely the fault
BMW FRM3 bmw e90 2010 keanu 3 319 Today 09:54 PM
Last Post: Willisodhiambo
BMW e90 320d m47non starter ryn079 6 206 Today 12:41 PM
Last Post: ryn079
  E90 power windows problem bawarek 4 1,269 04-15-2018 09:50 PM
BMW Inpa error BMW E90 325d diagnostic biela 4 2,601 04-14-2018 11:09 AM
Last Post: hojo29
BMW E90 (WHITE) CAS2 NON ELV FLASH PLEASE AutoHaus786 7 1,098 04-08-2018 10:34 AM
Last Post: Levanime
