E90 DME swap MEVD17
01-19-2018, 06:08 PM
E90 DME swap MEVD17
Car is 2011 335 N55 with mevd17 and is automatic
I have AVDi original but am a bit unclear on the procedure.
I think I should change isn in DME but AVDI didn't let me do that, not sure if that's possible with AVDI.
I tried changing isn in CAS to match new DME but that did not work, could not sync dme and cas.
Any ideas?
01-19-2018, 11:51 PM
RE: E90 DME swap MEVD17
I have idea - put your dumps here to clear situation. What happened with old dme ?
skype: temsky80
germancarstvo.blogspot.com
immo solutions bmw/mini/rolls-royce
reset isn in egs 8hp bmw/rolls-royce
 Thanks given by: rrador
01-20-2018, 04:57 AM
(01-19-2018 11:51 PM)temsky740 Wrote:  I have idea - put your dumps here to clear situation. What happened with old dme ?
What do i need just read old and new dme?
Not sure about what happened car was sent to me from another shop just for programming. They said it had a valvetronic fault and it would not start, they changed valvetronic motor and checked wiring and still same problem. But to me sounds like has to be somethig else, car should start with valvetronic fault I think
01-20-2018, 05:26 AM
As for me better way to write isn in cas.
For this u have to read both dme .
skype: temsky80
 Thanks given by: bawarek , rrador , forti
02-08-2018, 03:02 PM
Ok I figured this one out, I was just doing it wrong with AVDI.
Have to encrypt ISN before writing to CAS. Car starts no problem now but have another issue.
used ECU I got is from a car with DCT my car is automatic. I programmed it with ista p I also programmed dme with right ZU number with winkfp but I still always get errors about missing messages from DKG.
Any ideas on this?
02-08-2018, 06:33 PM
just clear ecu config,
but I would've just clonned, easier, cleaner, no additional adaptations of vvt, injectors and stuff like that.
Drive653
02-08-2018, 06:46 PM (This post was last modified: 02-08-2018 07:05 PM by rrador.)
(02-08-2018 06:33 PM)Levanime Wrote:  just clear ecu config,
I though cloning was not possible with these? I can try I already read both ecu with k-tag.
How do I clear the config? never tried that before.
Would it be just code ecu to default settings with ncs expert?
02-09-2018, 02:57 PM
Found it in INPA, thanks for the help. All good now.
  Mini control module swap i860 4 808 Today 11:09 AM
Last Post: larshutten
  BMW e90 M47 Injector Activation Tomski 4 246 Yesterday 05:04 PM
Last Post: Fogshore
  Steering wheel lock E90 2011 year damianh69 5 452 07-16-2018 11:45 AM
Last Post: HestonDiag
BMW BMW e90 ELV Fault b21playa 7 2,131 07-16-2018 08:14 AM
Last Post: damianh69
  NOx delete E90 MSD81 DME Willisodhiambo 3 1,096 07-15-2018 07:56 AM
Last Post: Willisodhiambo
