  • 4 Votes - 3.5 Average
EDC17CP14 ecu bricked by obd....The solution!
06-18-2017, 10:49 PM (This post was last modified: 06-18-2017 11:01 PM by hasslavane.)
VW EDC17CP14 ecu bricked by obd....The solution!
HI everybody,
i want to share my experience with ecu EDC17CP14 bricked by obd.
If you flashed this ecu by obd and had "bad checksum error" or simply an error at the end of programming, regardless of programming tool, you had probably locked your ecu in programming mode.....--> CAR NO START
Boot mode restoring, immo off, eeprom changing...all this will not work!
Don't panic, your ecu is not dead.
The solution is to find same SW original file online in a database (I found mine on ecubit.com) and flash it BY OBD mode in order to exit programming mode. Important, file must be bootmode read file and not partial obd read.
No pb with RSA or OTP area, it will work!
This will restore eeprom and allow car to start again.
I hope this will help because i saw lot of topics with same problem and no real solution.
 Thanks given by: Silverdisc , dinho , KriyenKPp , Perryking
06-18-2017, 11:10 PM
RE: EDC17CP14 ecu bricked by obd....The solution!
flash the ecu with odis /vaspc or vag can pro
and it will also starts.
 Thanks given by: KriyenKPp
06-18-2017, 11:16 PM (This post was last modified: 06-18-2017 11:18 PM by ghassun.)
(06-18-2017 10:49 PM)hasslavane Wrote:  HI everybody,
No bro it's not necessary well I have a friend who flashed an original software fro VW by ODIS and then all of a sudden it's bricked and we tried many tools from the aftermarket but it doesn't work and once the ECU is locked u can't flash it all even by original tool bro so it's not true that if u flash it by original one then it will work cause it's already locked (locked means that you are not allowed to flash it since it's not matched with immobilizer) so once you remove immo and in my friend case the immobilizer was not able to be programmed wither by online function or bypassed because the ECU is damaged all of a sudden then u can flash it other wise u need to bypass it by very expensive tools and ost probably it's not gonna work as per my experience and my friends who faced this issue many times before
06-18-2017, 11:25 PM
i have reflash ecu with odis after other have try to flash it with kess v2 over obd port.
and the cars want start.after the odis reflash all wors as before.
no problems.
06-18-2017, 11:58 PM
(06-18-2017 11:25 PM)ladadens Wrote:  i have reflash ecu with odis after other have try to flash it with kess v2 over obd port.
no problems.
That's what I'm telling that once it's locked u can't reflash it and even if it's flashed u need to remove the immo, but if the control unit is bricked then no way at all
06-19-2017, 12:01 AM
no problems.
ODIS is a solution, it's true but i don't have it.
Here you can solve the problem with same tool which crashed the ecu.
06-19-2017, 12:31 AM (This post was last modified: 06-19-2017 12:31 AM by razor1199.)
What if i reflash it via ktag bdm using ori dump?
If helped hit "+Thanks" and "+Reputation" button Smile.
If wrote something interesting also click on "+Thanks" Smile.
Have a nice day.
06-19-2017, 05:38 AM
Someone bring me today a Audi A5 3.0 TDI EDC17CP14 ecu for dpf off, some other guy try with volta before and write file back in bootmode with bad checksum.
Car dont start, fans are on, but stil communication with vcds.
Now he came to me and i connect ktag, but no luck, i cant read or write file to the ecu, he even dont see ecu identification.
VAG > IMMO-LAMBDA-EGR-DPF-DTC's-EVAP-SAI-NOX OFF-HOTSTART :
MSA12 MSA15 EDC15 EDC16 EDC17 ME7 ME9 MED17 SIEMENS PPD / PCR2.1 SIMOS 3 7 8 9 10 12 18
www.ecu-solutions.com
06-19-2017, 06:23 AM
(06-19-2017 05:38 AM)MK2-VRT Wrote:  Someone bring me today a Audi A5 3.0 TDI EDC17CP14 ecu for dpf off, some other guy try with volta before and write file back in bootmode with bad checksum.
this is what op posted on another thread , your part2 of this so looks like x17 is the answer
Quote:I problem: ECU VAG EDC17CP04/14 blocked writing MOD by OBD (so called EEPROM crash)
caused by: ECU remain in programming mode.
1. Read IROM / XROM and EEPROM in bootloader mode.
2. Fix IROM/XROM using bootloader readout and OBD ORI readout (you will probably need to paste part of map zone and chk/RSA zone)
3. Write fixed IROM/XROM by bootloader (do not touch EEPROM!)
4. connect ECU to the car and write repaired IROM/XROM (same used for bootloader) by OBD.
It will automaticaly fix eeprom problem.
Resolved
II problem: ECU VAG EDC17 blocked writing IROM /XROM by bootloader. Cannot read anymore IROM/EEPROM
Caused by: damaged sector 0 by interrupted writing
1. find someone with MAGpro2 X17 or T-BOOT tool
2. Write IROM / XROM by X17/T-BOOT using OPTIONS= ALL
resolved
Regards
MAGICMOTORSPORT Team
magicmotorsport
Forum Sponsor
 Thanks given by: razor1199 , MK2-VRT , franke232
Mercedes Benz needed high quallity can filter for w212 2015 with for diag or obd shervin 0 36 Today 01:54 AM
Last Post: shervin
  Repair Digiprog solution zogldibosnia 3 167 08-17-2017 01:21 PM
Last Post: zogldibosnia
  SAGEM S2000-1 IMMO OFF TESTED SOLUTION NEEDED ELAB014 17 6,898 08-14-2017 10:48 AM
Last Post: majorel
VW EDC17CP14 IMMO OFF bryglu 11 445 08-14-2017 08:42 AM
Last Post: dct-performance
VW VW Fox steering electric blocked SOLUTION Derick Oliveira 4 175 08-12-2017 02:58 AM
Last Post: Derick Oliveira
VW EDC17CP14 EGR OFF khaled diag 2 117 08-11-2017 03:23 PM
Last Post: builes13
  Solution immo off Espace 4 0281011324 Sirocco 0 72 08-09-2017 09:26 PM
Last Post: Sirocco
  EDC17CP14 immo off Mrpromega 0 79 08-07-2017 05:12 AM
Last Post: Mrpromega
  Audi A4 B8 Bosch EDC17CP14 DTC P2015 deluss 6 213 08-02-2017 01:48 AM
Last Post: MK2-VRT
BMW EDC17CP02 write with KESS over OBD? bmw335coding 16 387 07-31-2017 11:56 AM
Last Post: sigaik
