  • 10 Votes - 3.3 Average
EPC unknow Lan-ID Error help needed
01-11-2017, 05:11 AM
Mercedes Benz EPC unknow Lan-ID Error help needed
i have a problem using my System with the EWA Key. When I look in the EWA-Admin-Tool to generate a Key to use it, i get everytime the "Unknown Lan-Id". I checked my drivers on pc and it looks like ok, but i realy don't know what is the problem.
Thank you for your help.
01-11-2017, 05:22 AM (This post was last modified: 01-11-2017 05:30 AM by Dollsburg.)
Mercedes Benz RE: EPC unknow Lan-ID Error help needed
Is this a Standalone installation in the same Environment as Xentry Das and Wis Standalone or Is it the Full installation on PC that is not a SDsystem?
Which version of windows/ year of installation and type? Kindly shed some light on your installation just so we may see the type of problem and assist!
Could be you've applied a fix for Data Card! Or u r just using the wrong keygen all together!
Anyway if you have Admintool, in run, cmd, type IPconfig! Then try to open IE(internet explorer) then favorites and select ewanet, to go to reset ewa password. Here at IE you will see whether Java and important stuff are installed and green in color! Also do not use pre-installed java from net! No use java provided in Baseline disc!
If you have pre-installed updated java with security updates! Clear it from programs and regestry tool and cold boot your pc!
Go into the auto mechanic, you've got to know computers to be able to work on the cars.
You have to look for teachers. If you want to be a mechanic, go hang out with mechanics.
01-11-2017, 05:27 AM (This post was last modified: 01-11-2017 05:29 AM by anonimo.)
I have Wis Sandalone installed and it works great. I installed also EWA for EPC only and there is the Unknow Lan-Id Error.
It is windows 7 64bit Ultimate Versison SP1.
It is a full installation on a PC. I installed Xentry 09.2016 with DAS and Wis Standalone. Also installed DTS Monaco and VEDIAMO.
Thank you
01-11-2017, 07:26 AM
Uninstall all LAN and WLAN adapter, also the virtual Adapter. Restart the PC and install the LAN und WLAN adapter new.
 Thanks given by: anonimo
01-11-2017, 02:47 PM
(01-11-2017 07:26 AM)rudi2 Wrote:  Uninstall all LAN and WLAN adapter, also the virtual Adapter. Restart the PC and install the LAN und WLAN adapter new.
sorry dont work for me. thank you
01-11-2017, 08:31 PM
Post: #6
having the problem here too.
running win7 x64 on a dell 1525 laptop
another dell D630 doesnt have this problem.
both hdd are cloned identically.
xentry and das is working fine (via lan cable. never bothered to test wifi)
removed all hidden adapters. remove install adapters. all return with unknown lan ID.
~If I helped, press "thanks" and "reputation". Thanks!~
01-11-2017, 11:06 PM
Post: #7
i have had this also before. i try a lot from the net, on the end i install all new starting with win7 64bit. after all ok,
01-12-2017, 12:16 AM
Post: #8
hello, i solved it very easy. you must go to your device manager and make show hidden adapters. there are different adapters that must be delete. after that the number appears and you can generate a key for the ewa. It works for me.
i looked at mhh and find this threat with the solution:
http://mhhauto.com/Thread-EWA-net-unknow...Windows-10
good luck
 Thanks given by: 2007RennTechSL600
01-12-2017, 12:48 AM
Post: #9
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\TCPIP6\Parameters]
"Dhcpv6DUID"=hex:00,01,00,01,1d,d7,fa,c7,d4,be,d9,29,74,cf
"EnableICSIPv6"=dword:00000001
"DisabledComponents"=dword:00000001
make reg file from the above, run it and reboot .
S K Y P E = sydiagnostics
 Thanks given by: webmaster , anonimo , Schang , ardicela , Jay , Floryn_Plo , Dollsburg , mercomoh , Neistovij , JarsaR
Mercedes Benz EPC install no EPC media found PROBLEM landylro 14 3,102 02-04-2018 01:29 AM
Last Post: MidaX
Mercedes Benz Ewanet for Epc/Wis 01/2014 icons for WIS/ASRA & EPC not available in ewanet browser kilog 1 94 01-19-2018 06:14 PM
Last Post: kamaleon
Mercedes Benz Need a Help! C4 Mux no connecting via LAN zioweb 8 447 01-11-2018 03:52 AM
Last Post: zioweb
Mercedes Benz C4 Mainboard faulty (no LAN connection) rodaher 1 149 01-09-2018 10:48 AM
Last Post: Freezzby
  EWA net unknown LAN id Windows 10 patcash 18 13,796 01-05-2018 04:54 AM
Last Post: Dublover
