  • 22 Votes - 3.32 Average
EWA Admin Tool Guide
08-05-2011, 01:30 AM (This post was last modified: 08-05-2011 01:33 AM by aiklee74.)
Mercedes Benz EWA Admin Tool Guide
Purpose of this document
This document describes the EWA Admin Tool Interface of EWA net which is used to update, manage and maintain the WIS and EPC Databases as well as managing the state of the server.
Introduction
Besides the software installation, the applications need to have access to certain databases for content data. This content is not installed within the setup of the software but needs to be updated after installation. The aim of this behavior is to decouple software and data update and minimize the downtime of the applications.
This document describes the use and function of the EWA Admin Tool. The following use cases are documented in this description:
.Start of the Tool
.Starting and Stopping of EWA services
.Installing Databases for EPC
.Updating Databases for EPC
.Removing Databases for EPC
.Installing Databases for WIS
.Updating Databases for WIS
.Removing Databases for WIS
.Wiping Database content (Cleanup)
.Usage of the Tool
.Logging and Troubleshooting
Startup of EWA Administration Tool
The EWA net Administration tool can be started using the favorites menu inside the Internet Explorer. This entry is created during installation and is only available on the server.
[img][Image: admintoolguideimage002.gif] By aiklee74 at 2011-08-05[/img]
Picture 1: Start of EWA net Administration tool using the favorites menu
The EWA net Administration tool can be only started on the EWA net server. If the link to this tool is not available, it can be started manually using the command
[EWA_HOME]\ewa_admin\EWAAdmin.exe
where EWA_HOME need to be replaced with the directory where EWA net was installed.
Starting, Stopping and Monitoring of EWA core services
With the EWA Administration Tool it is possible to influence the availability of the server and see if it is running. The Administration tool acts as a service monitor and shows if the needed Windows services are running or not.
[img][Image: admintoolguideimage003.jpg] By aiklee74 at 2011-08-05[/img]
Picture 2: Service Monitor Page for the Server
Within this panel the EWA net server (application server) can be started and stopped. This is more or less a shortcut for the Windows “Services” view.
Also within this panel the user management database (i.e. for specific user data, FIN Cache,…) can be started and stopped.
Quote:Note:
Database “start” and “stop” is not simply starting and stopping services. A “stop” always also stops the corresponding TransBase multiplexer service. And “start” always starts both the database engine and the TransBase multiplexer service.
If the services are stopped the application server will not be available for all users. Please take this into account when starting or stopping services.
ENJOY !
Continue.... Next Thread. EPC net / WIS net Database Maintenance
 Thanks given by: krazysat , Rocinante , jeslfm
VW VAS-PC v.19.01.01 Install Guide getaibose 5 11,800 09-20-2017 07:51 AM
Last Post: down_load
  DTC removal guide needed olks 0 166 09-08-2017 04:17 AM
Last Post: olks
Mercedes Benz Mercedes EPC/WIS/EWAnet Video Installation Guide 2014 Yudi 90 41,679 08-23-2017 11:04 PM
Last Post: david_dung
  UPA USB ECU Programmer V1.3.0.14 Installation Guide ! pattersonlyy 0 308 08-14-2017 01:01 AM
Last Post: pattersonlyy
AA Bosch-logo Bosch ESI Installation guide webmaster 96 106,356 08-10-2017 03:26 AM
Last Post: Bartekj
Mercedes Benz Original Mercedes EPC/WIS/ASRA User’s Installation Guide webmaster 1,113 478,671 08-01-2017 08:59 AM
Last Post: ToMiBoY
Mercedes Benz Full Das Xentry installation Guide 2015 Yudi 177 97,406 07-26-2017 07:46 PM
Last Post: ganbaa
  Ford F 350 Diesel 2003 Turbo removing and re installing guide Khadus 3 1,717 07-25-2017 07:41 PM
Last Post: tomcarter
  Perkins EST 2015A v1.0 [01.2015] + Patch + installation guide AUTO7 22 3,420 07-17-2017 09:04 PM
Last Post: peppo1977
Mercedes Benz Mercedes DAS - Xentry 09/2014 Installation Guide - [With all Solutions and Mod DVDs] kalatopas 18 10,162 07-06-2017 03:24 AM
Last Post: c350king
