Engine Swap W210 -> W463 - issues
04-22-2018, 01:00 AM
Mercedes Benz Engine Swap W210 -> W463 - issues
Greetings,
I made a swap from old 3.0 K-Jetronic automatic, to a bigger engine from W210 (WDB2102701B070196) in my G class.
G class VIN is:WDB46322817071661.
Old transmission was hydrakinetic, now I have transmission which must know the velocity of my car. I swapped only the engine and transmission. Odometer is old, and velocity of the car was taken from reductor mechanically, now I need to inform my ECU/transmission ECU about velocity. Because transmission is now in emergency mode, it doesn't shift gears. As far as I've been informed, it's taken from ABS system. I've got my old ABS under my hood, but I'm willing to connect ABS system from W210 to my old ABS sensors and to new ECU by CAN.
Or can I just connect my old ABS to new system by CAN? (old ABS: 0 265 201 030)
Do anybody did that before? Maybe do You know better ways to do that? I appreciate every single hint. I guess I need schematics which I tried to find unsuccessfully :/.
04-22-2018, 08:30 PM
RE: Engine Swap W210 -> W463 - issues
To make the engine exchange work well, you need to have a compatible combination of all relevant speed related modules.
ABS pump / differential / transmission / ECU / cluster must all be correct combination.
If you try to mix the result will be random. If this engine exist in W463, then the part numbers also must be same for speed related parts.
 Thanks given by: nekju
04-23-2018, 12:26 AM
Thank You, so, I'll try to connect ABS from W210 to make it work.
  m113k swap to w203 help Benztek 5 845 05-13-2018 05:53 PM
Last Post: olegaustin
Mercedes Benz I NEED DUMP FOR KYE MERCEDES W210 musta 3 366 05-13-2018 01:03 PM
Last Post: DrSimLock
Mercedes Benz Mercedes W210 smart key problem miki1986 0 194 05-12-2018 10:26 PM
Last Post: miki1986
Mercedes Benz Ecu swap c200 cdi delphi unit crd.11 Funkyou 4 592 05-09-2018 01:39 PM
Last Post: nafa
Mercedes Benz W210 ECU & other than SD diagnostic tools nekju 1 247 05-05-2018 12:45 PM
Last Post: diagnostix
