  • 1 Votes - 4 Average
Error install Vediamo V05.01.01
08-20-2017, 08:52 AM
Hi all members , have Error during installation of vediamo V05.01.01, see pictures.
On the computer, I installed:
Windows 7 32bits, xdos 03.2017, dts monaco
Thank you for your help
Attached File(s)
20170820_191752 2.rar
File Type: .rar
Downloaded: 48 times
 Thanks given by: mucki49
08-20-2017, 09:11 AM
RE: Error install Vediamo V05.01.01
Start installation as Admin! Seems like it has something to do with File and Folder Permissions! In folder options enable read&write, permissions for the folders in C://!
1.In Windows Explorer, right-click the file or folder you want to work with.
2.From the pop-up menu, select Properties, and then in the Properties dialog box click the Security tab.
3.In the Name list box, select the user, contact, computer, or group whose permissions you want to view. If the permissions are dimmed, it means the permissions are inherited from a parent object.
Go into the auto mechanic, you've got to know computers to be able to work on the cars.
You have to look for teachers. If you want to be a mechanic, go hang out with mechanics.
 Thanks given by: Marcos , mercomoh
08-20-2017, 09:36 AM (This post was last modified: 08-20-2017 09:38 AM by mercomoh.)
(08-20-2017 09:11 AM)Dollsburg Wrote:  Start installation as Admin! Seems like it has something to do with File and Folder Permissions! In folder options enable read&write, permissions for the folders in C://!
I have installed it on a HDD it installs normally, but on an SSD it is necessary to create a folder manually in (C / windows / systeme32), if It can help ..
SOLVED
08-21-2017, 03:31 AM
Hi..
No need to create any folder.. just run as ADMINISTRATOR.
If you LIKE_it&HELP_you PLEASE Click on REPUTATION and THANKS
 Thanks given by: W211 , mercomoh
08-21-2017, 07:39 AM
(08-21-2017 03:31 AM)cocoh Wrote:  Hi..
I run it as administarteur, it did not work, I tried several times, nothing, when I created the file, it works, I did not understand anything, on hdd it installs all alone but on ssd I have to create this folder
11-13-2017, 08:36 AM
Mercedes Benz RE: Error install Vediamo V05.01.01
Change: Program Compatibility Mode (Windows XP SP3) and run Admin
at the end of the installation, start the Task Manager and complete the process cmd.exe * 32
Remember the THANKS and + buttons REPUTATION - Thank you
Handshake
 Thanks given by: Dollsburg , mercomoh
Mercedes Benz Vediamo CBF Files DATABASE - Free for all MHHAuto members olo666 51 40,341 Yesterday 11:53 PM
Last Post: ckarstk
Mercedes Benz Vediamo W176 electric folding mirror - CAESAR:ComCoordinator: 01025 kminhtri 7 771 Yesterday 05:33 PM
Last Post: MegaCar
  W212 7G M Mode Variantcoding with Vediamo TuGrA 36 6,267 02-23-2018 10:36 PM
Last Post: rabaukee
Mercedes Benz w212 e550 code out airmatic with vediamo mertd93 4 608 02-22-2018 02:19 PM
Last Post: fto0om85
Mercedes Benz Vediamo v05.00.05 FREE Activations for MHHAuto Members! Milanezu 4,575 620,937 02-22-2018 02:41 AM
Last Post: Balyanchic
