  • 38 Votes - 3 Average
FAULT ABS RENAULT LAGUNA 2
11-07-2012, 01:46 PM
DF185 - Circuit / internal supply solenoid valve servo brake
- Status unknown
- present
SOMEONE KNOWS HOW TO REPAIR DAMAGE OR HAS THIS SCHEME WITH VALUES
URGENT PLEASE HELPE-ME TANK YOU whew
11-08-2012, 08:18 AM (This post was last modified: 11-08-2012 08:36 AM by kos9979.)
RE: FAULT ABS RENAULT LAGUNA 2
THIS IS FOR VDIAG 08 & 0C
check the car if has System equipped with Electric Brake Assist Emergency
check parameter screen PR041 and tell which is A0,B0,D0,E0 E1
if yes is A0,B0
Check the condition and correct connection of the servo plug.
Check the connection and condition of computer connector and 6 contacts to the servo.
Check to ensure electrical continuity at the following links:
- Connector 4 servofrenouepafi contact 17Fis computer
- Connector 3 servofrenouepafi contact 31Fis computer
Ensure also the insulation between these connections.
Visually check the wiring of the brake booster.
Check the resistance of servofrenouR = 2 Z. If the resistance is not correct, replace the servo.
Ensure that no voltage + 12 V after mains switch on the brake booster between the contact 4 and body.
If the voltage is incorrect, contact the Technical Support Department (Techline).
If all checks are OK, reconnect the computer and the servo and then turn off the faults of computer memory.
Replace the SERVO if the fault reappears.
 Thanks given by: auto421 , maxcombor
11-08-2012, 09:21 AM
(11-08-2012 08:18 AM)kos9979 Wrote:  THIS IS FOR VDIAG 08 & 0C
if yes is A0,B0
thanks for the reply, I already did these diagnoses line 4 does not have 12volts not mark anything, I wanted Saer 12volts output if the ecu or abs sensor servant. tank you regards
11-08-2012, 09:42 AM
if yes is A0,B0
i dont understant you the problem is the abs/esp ecu replace it
09-20-2016, 01:38 PM
And cant be repared?
PRESS REP BUTTON if helped ListenListen
  renault laguna card precoding xipsilon 8 658 Yesterday 10:23 AM
Last Post: kaczor2502
  unlock laguna card 2 kaczor2502 3 113 11-15-2017 02:55 PM
Last Post: decode_cz
Renult Laguna II new card does not work properly kaczor2502 3 96 11-13-2017 11:37 AM
  dtc off file laguna 3 edc17cp58 manueldord 1 92 11-11-2017 06:50 AM
Last Post: Ddnc
Renult laguna 3 abs carprog obd manueldord 0 104 11-07-2017 05:36 AM
Last Post: manueldord
  need help mileage abs Renault capture shmuk 0 66 11-07-2017 12:39 AM
Last Post: shmuk
  Laguna II ecu S2000 virgin? Viliux2 1 56 10-26-2017 08:36 PM
Last Post: junnnior
  Laguna 2 2005 1.9 DCI 0 281 012 588 munja 0 36 10-26-2017 06:15 AM
Last Post: munja
  Renault Laguna II 2003' Heleje 1 83 10-17-2017 05:49 AM
Last Post: Heleje
Renult Airbag Laguna autoliv crash marpaj 2 106 10-11-2017 02:07 AM
Last Post: marpaj
