FIAT DUCATO 2.3mjd DTC remove P0638 throttle control valve OFF
11-14-2017, 06:53 AM (This post was last modified: 11-15-2017 12:27 AM by boki.)
Fiat FIAT DUCATO 2.3mjd DTC remove P0638 throttle control valve OFF
Hi. if anyone can remove dtc P0638. Somebody stole the flap, new is too expensive, used is hard to find. thanks a lot
Attached File(s)
ducato flash.rar
File Type: .rar
Downloaded: 1 times
11-14-2017, 07:02 AM
RE: FIAT DUCATO 2.3mjd DTC remove P0638 throttle control valve OFF
here you have dtc off
Attached File(s)
1037529160(P0638).rar
File Type: .rar
Downloaded: 1 times
11-14-2017, 08:14 AM
(11-14-2017 06:53 AM)boki Wrote:  Hi. if anyone can remove dtc P0638. Somebody stole the flap, new is too expensive, used is hard to find. thanks a lot
DTC OFF will not slove a problem
dpf, egr, dtc, adblue, swirl flaps, tva...100% working solutions
11-14-2017, 08:26 AM
if you want me I can do it ... 100% testet and ok
if you want to do the job you can write me in pm or add me to sky, and tomorrow morning I will send the file
solution unplugged
.: Map Engine Speed :.
https://www.facebook.com/mapenginespeed/
skype contact: Giacomo_Map_Engine_Speed
winols user
dpf, egr, adblue, dtc, tva, lambda, swirl off... stage 1, stage 1+, stage 2, stage 3 engine ecu
don't ask for free file
Fiat Tuning File Ducato 2.3 130Multijet Marelli MJ8F3H volter 3 116 11-16-2017 05:56 PM
Last Post: afrpowersolution
  VW EDC17C64 DTC remove P1570 & P0197 SPIDER MAN2 4 184 11-15-2017 11:51 PM
Last Post: autobirotula
Ford Fiat Marelli mjd 6f3 dtc off please mercas 3 135 11-11-2017 06:36 AM
Last Post: lsdlsd88
Fiat Fiat ducato 3.0 157 hp Gorcho 3 130 11-10-2017 07:05 AM
Last Post: ADC-Tuning
Fiat Fiat Ducato 3.0 157 hp problem Throttle Actuator Control Range Gorcho 1 59 11-10-2017 04:45 AM
Last Post: lsdlsd88
  Need DPF off Ducato edc17c49 LiquidTrash 2 103 11-09-2017 07:38 AM
Last Post: mariusica_boy
  DTC remove sid304 mr_tran 3 209 11-04-2017 07:43 AM
Last Post: mr_tran
  Remove DTC P1556 on EDC15 LiMuBai 9 250 11-03-2017 11:51 AM
Last Post: LiMuBai
  DTC Remove free software Smartuning 72 122,586 11-01-2017 12:26 PM
Last Post: carlab
  VW GOLF EDC17C64 DTC remove SPIDER MAN2 2 143 11-01-2017 12:07 AM
