Latest news: --- VW 2.5TDI AUTOMATIC TO MANUAL GEARBOX HELP --- VW Phaeton 3.0tdi P1018 off --- NEED PIN CODE AC MASHINE BOSCH ACS751 DRIER FILTER RESET --- BAD CHECKSUM IN BSI DUMP --- DTC OFF volkswagen passat 2.0 tdi 140cv --- Audi clear --- Volvo V40 Pedestrian Crash P31406938 --- Enabling amg feature on NTG5 telematics --- clio sirius 34 emulator quick (easy) question --- need dtc off passat b5fl AVF --- Renault 1.9 dci --- Renault logan 1.4 ems3132 need immo off --- 3.0tdi dpf off --- Jeti 4.33 --- Radio RNS 315 VW code --- VW Golf VI Egr off (beginner) --- Nissan x trail 2.0dci failed flashing thru obd. No contact. --- radio code vw RNS 315 --- john deer tractor --- Need hyundai starex vin to pin --- citroen xsara 2,0 hdi immo off 3 plug ecu --- VW PPD 1.2 checksum please!! --- help dtc off edc15c5 --- VW EDC17CP46 need wirning diagram --- Some useful Immo off bins tested by me. --- Help with sdconnect c4 repair --- Learning key coding --- KTM DUKE 200 Vmax off --- 2008 bmw 335i help pllease cas --- a6 c6 programing --- 2016 Kenworth red cummins Help with insite be able to change parameters --- Renault Kango 1.9 DTI 2003 edc15vm+ Pinout --- Xvdiag nano ids mazda after second day will come out error masage --- ServiceMaxx Key --- FVDI 2014 making dealer key for VW - "Can not write transponder" --- ssangyong kyron immo off 95320 2011 --- Sid 301 Renault --- DDL 8.02 Registration Problem --- SW Upg. ???? --- immobilizer problem --- A4 1.8T 150hp ME7.5 Lambda Cat off --- Kts 520 --- EWA Start key. --- mazda 3 2014 it asking for a ssu outcode could some one help --- W166 350d EDC17 Mileage dpf --- Touran 2.0 Tdi PD smoking problem --- ECU Ford Fiesta Siemens SIM210 clone / virgine --- mitsubishi pin --- Since remap 330d i have eeprom fault 1640 --- xprog read mcu mcu MC68HCP11E1VFN ---
