  • 39 Votes - 3 Average
Fiat ECUScan 3.6.2 + FINAL Crack ALL OS!
08-08-2012, 08:34 PM
Post: #19
RE: Fiat ECUScan 3.6.2 + FINAL Crack ALL OS!
I read yesterday a 3.6 diesel with FES Ducato 3.0 ABS which
no problem !!
FES 3.6.2 I get not run on XP, i dont no why!
i result the instraktion but it works not
08-08-2012, 11:03 PM
Post: #20
FES 3.3,FES 3.5 and FES 3.6 good working!
FES 3.4, 3.4.2 and 3.6.2 is unstabile! Crash sometime!
 Thanks given by: salvatore1948
09-05-2012, 06:36 AM
Post: #21
I've done, everything right, just like the readme file.
But if I don't rename the crack file to "FiatECUSCAN2" it appear an error, then a white window with "LOADING", but stop there.
If I rename it says "Data File Error".
Can anyone help me?
09-05-2012, 08:13 AM
Post: #22
(09-05-2012 06:36 AM)kurushi Wrote:  I've done, everything right, just like the readme file.
Can anyone help me?
Mate
Forget about this
Try here http://mhhauto.com/Thread-MulTieCUScan1-...ltiecuscan
There's new version of FiatEcuScan. Now it is named MultiEcuScan
Good luck
 Thanks given by: perotok , kurushi
09-13-2012, 08:31 AM
Post: #23
Fiat RE: Fiat ECUScan 3.6.2 + FINAL Crack ALL OS!
Can anyone help me?
Mate
Forget about this
Good luck
Works perfectly, but to disable service reminder it ask me for an yellow cable.
Anyone now where I can get it? Or I don't need it?
09-13-2012, 08:58 AM
Post: #24
Can anyone help me?
Mate
Forget about this
Good luck
Yellow canble it is one of the 3 adaptors you need. I made one adapor which includ all that three adaptors
Please name in what car do you want to reset Service interval
If here you they said that you need ELM C19 adaptor you need to make the 3rd adaptor. You can find the schematic in the end of that page
Good luck
 Thanks given by: kurushi
09-14-2012, 03:03 PM (This post was last modified: 09-14-2012 03:06 PM by kurushi.)
Post: #25
Can anyone help me?
Mate
Forget about this
Good luck
Good luck
I'm using ELM 327... Do you know were I can get the cables on your link, the one that have to be modified.
09-14-2012, 07:10 PM (This post was last modified: 09-15-2012 09:34 AM by Patrian.)
Post: #26
(09-14-2012 03:03 PM)kurushi Wrote:  I'm using ELM 327... Do you know were I can get the cables on your link, the one that have to be modified.
I'm sorry I have no link
Me I did it myself.
I use a DIP Switch in ELM327 for this adaptor to change the CAN BUS line leke this
pin 6 to pin 1 and pin 14 to pin 9
Good luck
 Thanks given by: vincano
09-17-2012, 01:29 AM
Post: #27
Me I did it myself.
Good luck
Do you have some photos of your job? Do you have any schematic that you can post or send me by PM?
  Tunerstudio crack bezuk118 1 340 01-04-2017 02:06 PM
Last Post: laser411
Ford FORD ETIS 2015 INSTALL HELP AND CRACK HELP FOR ALL MHH MEMBERS norman1967 30 22,492 01-03-2017 10:26 AM
Last Post: norman1967
  Bosch Esitronic 2013/1 crack Jan1980 3 1,812 12-26-2016 05:18 AM
Last Post: ahmed3000
VW Need Crack for ALLDATA 10.52 david.obd2 8 443 12-14-2016 09:12 AM
Last Post: david.obd2
  LPG Diag software Crack needed/chalange Weebu codemeter craciunaero 2 246 11-28-2016 12:17 PM
Last Post: craciunaero
VW vag-com VCDS 15.7 Crack software xcar360 30 42,743 11-25-2016 08:32 AM
Last Post: mehdi_gsm
  Mitchell OnDemand 5.8.2 2013 Only Crack jhrccs 3 5,022 08-08-2016 06:36 AM
Last Post: sixcode
Mazda Vediamo 4 crack PLEASE HELP!!! [email protected] 6 849 06-24-2016 08:50 AM
Last Post: obdstart
AA+MHH Vivid Workshop DATA ATI v.10.2 EASY CRACK!! rickyw88 71 136,748 06-04-2016 02:56 AM
Last Post: thulasi.gumede
  Automotive Expert crack? boloyoung 6 1,216 03-03-2016 08:24 PM
Last Post: hasoon2000
