  • 43 Votes - 3 Average
Fiat ECUScan 3.6.2 + FINAL Crack ALL OS!
09-17-2012, 02:23 AM (This post was last modified: 09-17-2012 02:23 AM by mattydr67.)
Post: #28
RE: Fiat ECUScan 3.6.2 + FINAL Crack ALL OS!
(09-17-2012 01:29 AM)kurushi Wrote:
(09-14-2012 07:10 PM)mattydr67 Wrote:
(09-14-2012 03:03 PM)kurushi Wrote:  I'm using ELM 327... Do you know were I can get the cables on your link, the one that have to be modified.
I'm sorry I have no link
Me I did it myself.
I use a DIP Switch in ELM327 for this adaptor to change the CAN BUS line leke this
pin 6 to pin 1 and pin 14 to pin 9
Good luck
Do you have some photos of your job? Do you have any schematic that you can post or send me by PM?
Schematics you find on http://www.multiecuscan.net
It is the schematic for Adaptor 3
Good luck
[attachment=10806]
 Thanks given by: ToMiBoY , gameiruz
09-17-2012, 06:20 AM
Post: #29
hi all, i need help. I can't make new multiscan work on PC. Can anybody PM me where to get FES 3.6.2 installation file? thank you in advance.
09-17-2012, 06:46 AM (This post was last modified: 09-17-2012 06:51 AM by mattydr67.)
Post: #30
(09-17-2012 06:20 AM)carbug Wrote:  hi all, i need help. I can't make new multiscan work on PC. Can anybody PM me where to get FES 3.6.2 installation file? thank you in advance.
How so?
What it is your problem?
Good luck
P.S. - try this and report
 Thanks given by: Milanezu , perotok , md_90 , carbug , ToMiBoY , erickdnt
09-17-2012, 09:13 AM (This post was last modified: 09-17-2012 09:20 AM by perotok.)
Post: #31
If you still have a problem with a multiscan
Then here's the link for FES 3.6.2
FES.txt
File Type: .txt
Downloaded: 469 times
For loader see the first post (from Mr.Patrian)
 Thanks given by: mattydr67 , esse , carbug , telefunken , ToMiBoY
09-18-2012, 09:11 AM
Post: #32
Hi. I can not extract file with this password.
09-18-2012, 01:09 PM (This post was last modified: 09-18-2012 01:10 PM by perotok.)
Post: #33
(09-18-2012 09:11 AM)anatoly Wrote:  Hi. I can not extract file with this password.
Mate
which password?
If you mean the password for the loader then read the first post carefully
password is good and works Tup
Password: Made By c4U ---------- copy/paste
Good luck Beer
 Thanks given by: vinnycaz , ToMiBoY
09-25-2012, 01:19 AM (This post was last modified: 09-25-2012 10:21 PM by carbug.)
Post: #34
i just tested FES 362. it is much stable than Multiscan 1.0 and it doesn't timeout easily. I still like the the old version which is stable for like ABS and Airbag diagnose. Thank you
09-26-2012, 11:40 AM
Post: #35
bonjour, je suis français, mécanicien auto multimarque et je viens vous faire part de mon expérience avec FES 3.6.0 pour ma part, j'ai eue 2 injecteurs à changer sur une fiat croma 1.9 jtm de 2005 125.000km, mon premier probleme à été que je ne pouvais pas réécrire mes codes de mes injecteurs neuf!
J'utilises une interface acheter sur le site dynodb.net : la fiatecuscan avec trois adaptateurs de couleur.
Je me connectes au moteur: ok
acces aux codes injecteurs: ok
onglet réglage et réécriture injecteur: ok
je les rentres: sa me di en cour et terminé !
je controle : PAS DE CHANGEMENT !!! mais quel poisse la voiture devais partir dans l'heure !!!
Apres grosse bataille et réflexion, j'ai enlever mon appareil fiatecuscan et j'ai rebrancher un vieux vag-com que je n'avais jamais réussi à faire fonctionner ( acheter 20€ sur le meme site )
Et là miracle déjà je lance FES : ok
je me connectes au moteur ..... JE croise les doigts et .... ok connecté !!
je vais dans l'onglet réglage et je recommences la manip pour rentrer mes nouveaux codes injecteurs : je clic : TERMINE
je vais controler mes nouvelles valeurs : OK sa marche !
Donc si vous avez le meme soucis je m'en suis sorti comme sa !!
voilà en espérant que sa peux aider!!
MERCI A TOUS CEUX QUI FONT TOUT SA .... BRAVO ..... MERCI Smile
12-14-2012, 01:39 AM
Post: #36
(09-05-2012 06:36 AM)kurushi Wrote:  I've done, everything right, just like the readme file.
But if I don't rename the crack file to "FiatECUSCAN2" it appear an error, then a white window with "LOADING", but stop there.
If I rename it says "Data File Error".
Can anyone help me?
FiatECUScan2 NEW.exe is loader, it try find original FiatECUScan2.exe [Program Files\FiatECUScan\FiatECUScan2.exe].
do not delete original FiatECUScan2.exe in folder [Program Files\FiatECUScan\FiatECUScan2.exe], you can rename FiatECUScan2 NEW.exe to loader.exe/you name/you girl name.
VW vag-com VCDS 15.7 Crack software xcar360 31 53,104 09-17-2017 05:16 AM
Last Post: nomic
Honda Neptune rtp crack or license? joeynapp 2 386 08-11-2017 10:54 AM
Last Post: franckrem
  Good technical data crack and keygen? Juicehead 7 516 07-18-2017 02:16 AM
Last Post: Xeon1
Mercedes Benz need crack abdolibi 1 292 07-05-2017 01:47 AM
Last Post: Fork62
Mercedes Benz i need full crack of xentry 3.2017 for win 7 64bit smartcarvn 1 816 06-30-2017 08:58 PM
Last Post: stupidguy
AA+MHH hp tuner crack software baker_mu 4 894 06-24-2017 09:28 AM
Last Post: ecumaster
Toyota Toyota Techstream GTS with crack , tested OK ! version 10.30.025 sony2 5 1,095 06-12-2017 01:55 AM
Last Post: gwee
  odis 3.3 + post setup 9.1 + crack cris_ova 1 662 05-23-2017 07:08 AM
Last Post: MarcinOslo
  Looking for Crack TecDoc Q2 2016 BadBoy! 1 716 05-05-2017 05:36 AM
Last Post: Sev17teen
  Mercedes DAS/XENTRY (07.2013) FINAL + (11/2013) Update TestPoint 7 4,915 05-02-2017 06:41 AM
Last Post: holloww
