Ford ECU MPC555
11-14-2017, 05:34 AM (This post was last modified: 11-14-2017 06:25 AM by drcoxx.)
Ford Ford ECU MPC555
Hey to all...
I have a little problem with a bricked ford ecu.
In car was a Delphi MPC555 with ext. flash installed with partnumber:
6S71-12A650-BC
It is not repairable.
No i search an ecu for this car.
The friendly dealer gave me 2 another numbers:
6U71-12A650-BA and 6U71-12A650-FA
For all 3 numbers i do not found a good ecu in the bay...
Can i replace it with any delphi mpc555 ecu, with or without ext. flash
and write over ids new software or i have to take these numbers?
Can anyone help me?
If it was helpfull, please push the thx and the rep buttom ;-)
11-14-2017, 06:28 AM
RE: Ford ECU MPC555 replacement?
Most replaceable ECU need to have same HW. If it has same PCB and components on it,then there is good chances to get it operable . But if one has different PCB,then it's most likely will be a problem. Different pinout,missing functions or ecu looking for nonexistent sensors or solenoids.
11-14-2017, 12:37 PM
RE: Ford ECU MPC555
You couldn't recover with IDS?
11-14-2017, 11:36 PM
Ford ECU MPC555
With ids i did not try... I wait for the ecu.
But i try when its here. Kess and ktag could not read software, i think its a hardwareproblem.
11-15-2017, 09:08 AM
RE: Ford ECU MPC555
Is this ecu was damaged in some case? Or it's just corrupted? If you have nothing to lose, it will not harm to try recover with IDS. If you got IDS check if PCM can be detected by IDS, if yes check if there are any DTC codes, and try to do software update, if IDS find update (I believe internet connection is needed) then will reprogram PCM and may repair if there is only problem with software.
11-15-2017, 02:58 PM
Ford ECU MPC555
I try it... But i think the chance is very very small
  ford delphi mpc555 6s71-12a650-bc pave 5 125 Yesterday 01:44 PM
Last Post: LuckkyLuke
  delphi mpc555 immo eeprom location Luk84 0 120 09-14-2017 06:07 AM
Last Post: Luk84
  Jaguar Delphi MPC555 Pinout? teefyg1 0 293 04-30-2017 11:16 AM
Last Post: teefyg1
  Delphi MPC555 Adapter Layout drcoxx 1 1,031 02-06-2017 12:51 AM
Last Post: euromod
  Ford Mondeo 2.0 TDCI 85KW 2006 - DELPHI MPC555 - NEED DPF OFF admirnexus 3 558 12-16-2016 09:33 AM
Last Post: admirnexus
Ford FORD FIESTA SIM210 SYNCHROHI, please i need synchro dumps for ford fiesta with ecu labase 0 470 08-24-2016 08:45 AM
Last Post: labase
  ford fiesta 2006 bosch edc16 ecu and visteon 1k78 dash ecu synch geerux 3 811 11-26-2015 06:25 AM
Last Post: geerux
Nissan Nissan Primera 1.9DCI 2007 MPC555 bdm dump rudiniiwwa 1 1,478 03-02-2014 09:10 AM
Last Post: tjracing
