HELP!! Keys do not work !!
07-13-2018, 06:46 PM
Mazda HELP!! Keys do not work !!
Hi everyone,
Been here a while and enjoyed searching and reading. Gotya say tuis forum Rocks!
But I Hope someone can help me. I have 2 keys for my w140 97 S500 and had a third key that I wanted to program; so with some reasearch I did here on Mhh Auto, I decided to tackle the job and remove the DAs2 box behind the clister and remove the 0D53J MCU chip and try to read so to use a mercedes calculator to generate new keys....well turns out my Xprog-M couldn’t read the chip (likey because had the HC05 adapter that the chip gets soldered to); so after several attempts to read, I removed it and placed it back onto the Das2 box with all connections soldered nicely and oriented correctly ( planning until I get a better HC05 adapter) but now none of my actual keys work even when I try to resynchronize them! The IR works but no just ghenlights come on; no lock/unlock features! PLEASE HELP!! Any constructive advice welcomed!Headbang
07-13-2018, 07:56 PM (This post was last modified: 07-14-2018 05:32 PM by bersch8688.)
RE: HELP!! Keys do not work !!
Maybe you damage your mcu with xprog
Or check your soldering again on your car.
Maybe help with with hot air
 Thanks given by: KriyenKPp
07-13-2018, 08:02 PM
(07-13-2018 06:46 PM)eltigre90 Wrote:  Hi everyone,
i think you have corrupted your dump.
xprog have the tendency of doing that from time 2 time!
 Thanks given by: KriyenKPp , tomek5550
07-14-2018, 01:36 AM (This post was last modified: 07-14-2018 01:38 AM by eltigre90.)
Mazda RE: HELP!! Keys do not work !!
(07-13-2018 07:56 PM)bersch8688 Wrote:  Maybe you damage your mcu with xprog to try read
Hot air is what i used but will look it over again...any suggestions if say the MCU was damaged?
Thanks for the reply....
Lets say the dump is corrupt any suggestions on repair or bypass??
07-14-2018, 07:43 AM
Can't you install a immo bypass?
________________________________________________________________________________​​______
07-14-2018, 12:17 PM (This post was last modified: 07-14-2018 12:21 PM by eltigre90.)
(07-14-2018 07:43 AM)Rocinante Wrote:  Can't you install a immo bypass?
Didnt know that was even possible! How would I do that exactly?
Also what reader(s) unit would you recommend that would easily read the MCU HC05 chip?
07-14-2018, 12:38 PM
Scroll to the bottom of this page.
See the white banner ad from carlabimmo?
Click on it to learn more. Smile
Please don't forget rep + thanks buttons below. It is free when you push them. Blush
 Thanks given by: Rocinante , eltigre90
07-14-2018, 02:30 PM
thank you!! Did some research already on the subject....always good to learn more! Tup well it turns out that I removed the DAS box but this time looked at the MCU pins under a jewelers loupe instead of my lighted magnifying glass; lo and behold there were approx 4 pins all around not making contact at all...took a solder iron this time to resolder, verified under loupe and replaced the box and BAM!; car started...!!! Thanks so much to everyoneDrive hey at least i know what a IMMOBYPASS option is now!Big Grin
Still any suggestions on a good reader for the HC05 MCU CHIP?!
 Thanks given by: Rocinante , diagnostix , KriyenKPp
07-14-2018, 05:34 PM
VVDI Prog rrad HC05 with adapter ;-)
Mercedes Benz [XDOS] DAS Call WIS NET F6(HELP) - WIS is not available Solution pesona 54 10,532 Yesterday 07:43 PM
Last Post: Eddieno93
  Smart 450 keys -immo martininkent 3 329 07-13-2018 11:49 PM
Last Post: figani
  SMART 451 KEYS martininkent 34 2,185 07-11-2018 10:18 AM
Last Post: audiomeca
Mercedes Benz W204 Not Starting, Remote Key Not Working K011 17 1,155 07-09-2018 09:17 PM
Last Post: radion360
Mercedes Benz DTS Monaco. How to make it work. temo4ka 26 15,219 07-08-2018 09:38 AM
Last Post: A2ua
