  • 2 Votes - 3.5 Average
HELP-TO How to find right damos files or use different models
08-20-2017, 04:49 AM (This post was last modified: 08-20-2017 04:54 AM by Khendal.)
Hello, can anyone help me to understand how it's possible to know which one damos file is right for a different ecu? For example :
Ori file:
Seat Leon Cupra 2.0TFSI 1P0907115C 0261S02337 386637
The info i've found to looking for are:
1P0907115C
D915A
N43J053
and 0020 should be the version number.
On the damos pack files there are all 1P****** series but not the 115C.
There are a D915A damos but there's written D915A_41W200, and other but not the mine (what is this number?should be 43J053?)
There are a lot of other type of ecu...which one is crossed to looking for a damos? How is possible to know which one ? For example 1K******* 8N******* or 8P******* ...
The first 2 characters should be the model series of car right? 1P for Leon Gen2, 8P for Audi 2.0TFSI and 1K for Golf Mk5 ..right ?
Thank you Smile
08-20-2017, 04:56 AM
RE: HELP-TO How to find right damos files or use different models
Have you tried to import the best fitting damos to your ECU? Sometimes the adresses match and you can work with that one. Otherwise you have to search for the right one. The map areas are usually similar. Only if you search for very special things it could be hard/impossible to find.
08-20-2017, 06:01 AM
(08-20-2017 04:56 AM)Bibobabo Wrote:  Have you tried to import the best fitting damos to your ECU? Sometimes the adresses match and you can work with that one. Otherwise you have to search for the right one. The map areas are usually similar. Only if you search for very special things it could be hard/impossible to find.
Yes i've tried but this is the problem... i can't find one for this car... Sad
This is the ori file if needed... i don't know which one use Sad
Attached File(s)
Seat_leon_cupra_2.0TFSI_240HP_1P0907115C__0261S02337_386637.zip
File Type: .zip
Downloaded: 3 times
08-20-2017, 06:27 AM
this file is a 100% match with an ED30 damos I have
WinOLS + DAMOS Importer+DAMOS Translator
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles)
08-20-2017, 07:55 AM (This post was last modified: 08-20-2017 09:40 AM by Khendal.)
(08-20-2017 06:27 AM)telucu17 Wrote:  this file is a 100% match with an ED30 damos I have
Oh really? Could you give me more info about that damos? Maybe already i have...
EDIT: i've just tried a fast check with my ED30 damos... a 1K0907115L_0010 ...and it seems match. Is this the file you were talking about?
  find an original file edc16c39 lancia delta 1.6mjet noriginal 1 66 09-14-2017 06:44 AM
Last Post: lsdlsd88
  Writing file, same upg sw different sw ??? vagnum 5 146 09-08-2017 02:10 AM
Last Post: lsdlsd88
AA+MHH EDC16U31 right ecu ? Cryjack 6 217 09-01-2017 10:26 AM
Last Post: Cryjack
  Iveco Daily Starting maps find geizol 2 115 08-31-2017 06:19 AM
Last Post: geizol
  Ford focus 2002 tddi wich tool do i use via obd? Kakabasa 1 145 08-14-2017 08:26 AM
Last Post: ominimicu
  [For Discussion] Is it possible to use tuned file many cars,trucks ...etc. Fouad 5 307 08-02-2017 01:39 AM
Last Post: 8ball
  Ducati Monster 696 find ori bin Ep-Tuning 0 104 06-23-2017 12:13 PM
Last Post: Ep-Tuning
VW How can I unlock and use a locked slave remap file Max50 9 811 06-18-2017 04:50 AM
Last Post: Domelec
  Need to find TABGBTS chrisdom 2 201 05-25-2017 05:59 AM
Last Post: chrisdom
Mercedes Benz kessV2 safe to use on 24v truck? gazchopper 4 357 05-02-2017 11:31 AM
Last Post: gazchopper
