Help IMMO_OFF IAW 6R.30 TMS370 Twingo
06-19-2017, 08:26 AM
Renult Help IMMO_OFF IAW 6R.30 TMS370 Twingo
Hello !
I need little help for immo off on this ECU.
IAW 6R.30 with TMS370C036.
Immo blinks on the dashboard.
I tried to mod the file and cut the PIN_25 but car still don't start.
(No ignition no sparks).
Here is my original and modified files :
ORI + IMMO_OFF TMS370C036.rar
File Type: .rar
Downloaded: 10 times
Thank you very much !
06-19-2017, 09:21 AM
Renult RE: Help IMMO_OFF IAW 6R.30 TMS370 Twingo
Try this file
Attached File(s)
IMMO OFF TMS370C036 MOD.rar
File Type: .rar
Downloaded: 7 times
 Thanks given by: kitnoos2002
06-19-2017, 09:45 AM
I'll write it now and test it tomorrow.
I'll keep you informed !
06-20-2017, 10:03 AM
(06-19-2017 09:21 AM)MMAMINE89 Wrote:  Try this file
Unfortunately it does not work.
Still no fuel pump or ignition.
Someone would have an idea of the problem ?
Thank you
06-20-2017, 09:28 PM
This is 100% tested solution.
IAW 6R.30_Immo off.rar
File Type: .rar
Downloaded: 4 times
Cut off pin 25
If not working search problem in the car. May Be wrong ground in engine or body. May be ignition relay (double relay for fuel pump and ignition),
Do You have communication with ecu ?
06-21-2017, 03:17 AM (This post was last modified: 06-21-2017 03:26 AM by kitnoos2002.)
(06-20-2017 09:28 PM)Solskier Wrote:  This is 100% tested solution.
Cut off pin 25
hello.
I tested the two relay and all the fuses. They are ok.
But I tested with other relay to be sure, and don't start...
I take ground with cable from batterie to ignition coil to be sure but don't have spark.
Don't found the 12v signal in the input side of ignition coil.
I don't know for communication with ecu. Car don't have OBD. Year 1996.
I will test your dump as soon as possible.
Thank you
06-22-2017, 08:43 AM
Don't work but I simulated the environment of the car with the relays, and the ECU seems to have an eratic operation.
Sometime the fuel pump signal is running 1 seconde after the ignition.
Sometime he does not start at all.
I think this ECU has an intermittent failure.
06-22-2017, 09:50 AM
You need check ecu with diagnostic tester - may by don't have communication, but in measured block, You can see for example status off immo, or engine speed signal.
06-23-2017, 11:30 AM
(06-22-2017 09:50 AM)Solskier Wrote:  You need check ecu with diagnostic tester - may by don't have communication, but in measured block, You can see for example status off immo, or engine speed signal.
Hello !
Don't work but after remaking some solder on transistor, now I have 4 spark and I can hear the fuel pump running for 1s after each contact.
crankshaft signal is ok.
What tool is needed to diag this ecu ?
This car has no OBD since it is from 1996, but has "Renault plug".
Thank's
  Immo Off Golf MM IAW 4MV 95080 autogaz1984 1 55 Today 06:08 AM
Last Post: konop11138
  Immo off Iaw 4wf.p8 Alexdoddi 4 739 06-25-2017 08:12 AM
Last Post: Alexdoddi
  RENAUL TWINGO IMMO OFF pavelGS_AL 3 63 06-22-2017 12:17 AM
Last Post: stef4o07
Peugeot Peugeot 406 IAW 48P.11 immo off fenir 6 343 06-17-2017 10:14 AM
Last Post: gkogkolos
  Renault Twingo 1.2 8v Sirius 32n S11013800 b immo off simiszer 9 1,332 06-17-2017 04:41 AM
Last Post: dom19
  help immo virgin magneti marelli iaw 6lp2.03 obdcarkey 1 103 06-14-2017 10:59 AM
Last Post: pankar
  Immo - Renault Clio 1.2 16v 2001 IAW 5NR2.C2 aqua_life 4 891 06-09-2017 02:40 PM
Last Post: rezak
  Need IAW 6LPB 2.2i 3FY Peugeot SOFT motoatmel 2 161 06-07-2017 04:20 AM
Last Post: motoatmel
  immo partial iaw 5sf8 hw 409 panda 2011 doct.tune 5 1,867 06-07-2017 12:58 AM
Last Post: bill42
Fiat punto 1.2 IAW 59F.M2 immo eMJot 6 191 06-05-2017 03:51 AM
Last Post: eMJot
