  • 4 Votes - 3.25 Average
Help me fix errors on Audi Q7 please
01-11-2017, 05:39 AM
Hello everyone, I have an Audi Q7 having dtc 02233 for module 55: Headlight Range as file autoscan attached, I replaced HEADLIGHT BALLAST for left headlight with part number 4L0 941 329, then I coding module 55 follow ross tech wiki guide as picture 1 with coding software: 0000031, then the software show me " coding rejected, error 22" as picture 2, and module have new dtc " module not coded" and "coding software" section show 0000255 as picture 3, can anybody help me fix these errors please,thank
Attached File(s)
Documents.rar
File Type: .rar
Downloaded: 9 times
01-11-2017, 06:32 AM (This post was last modified: 01-11-2017 06:33 AM by gordonasp.)
RE: Help me fix errors on Audi Q7 please
the problem is not the ballsast its the motor for moving the lamp
if you only change the ballast then you do not need to code
 Thanks given by: trunggt2007
01-11-2017, 06:43 AM
(01-11-2017 06:32 AM)gordonasp Wrote:  the problem is not the ballsast its the motor for moving the lamp
Thank, but I am new with Audi car, can you clarity for me, now how to I can fix error "module not coded", and fix dtc 02233
01-12-2017, 02:49 PM
Probably can't code because of the error, try fix the dtc first as per friends advice above then recode..no point throwing parts at it.
  HELP Please, AUDI WHIZZ NEEDED!! WILL PAY Audi Q7 - J519 laz79 22 378 10-01-2017 05:10 AM
Last Post: ladadens
VW vw. getta 2010 ecu fault code engin control unit incorrectly coded how to fix that iyad.nasser 1 175 08-20-2017 10:50 PM
Last Post: Ashraf6119
VW vw. getta 2010 ecu fault code engin control unit incorrectly coded how to fix that iyad.nasser 0 166 08-20-2017 10:39 PM
Last Post: iyad.nasser
VW Lods of errors after changing the ABS chatura 0 291 06-04-2017 03:20 AM
Last Post: chatura
VW VW Emissions Fix - Europe - Any details? Peahead 2 422 10-02-2016 07:13 AM
Last Post: Bibobabo
  Audi A8 errors after remap (DPF OFF)? HELP MaiiQ 15 1,659 05-01-2016 10:58 PM
Last Post: MaiiQ
VW how to fix or clear DTC steering wheel golf6 benkacem 0 364 01-29-2016 02:04 AM
Last Post: benkacem
VW VAG ETKA Plus 7.5 lexcom H0041 fix sixcode 0 3,995 01-02-2016 12:25 PM
Last Post: sixcode
  hot start fix Vw Golf 5 BKC kimmy 2 836 07-06-2015 10:21 PM
Last Post: majsterx
  2005 Audi A8 errors P0174 and P0171 koziolek 3 1,058 06-12-2015 07:28 PM
Last Post: big mechanic
