  • 2 Votes - 5 Average
Help needed - 2010 W212 with SLA (TSA) not working
10-17-2017, 02:11 PM (This post was last modified: 10-17-2017 02:21 PM by McTallman.)
I have a 2010 E350 Cdi 4matic AMG with traffic sign recognition fitted as original option (513). Have updated system with map with A2128270200 (v10) DVD and Telematics dvd A21282700-001, but still onle get error "not avaiable in your region" even avter checking settings and reset units (and wait over night) 1087
I feel there is one or several settings somewhere that I have missed, but cannot seem to se where. Has anyone else had this experience and/ or can help me to get this function active?
Have Xentry 9/2017 with C4 avaiable Pc
The car has got Comand APS, Keyless Go, Distronic plus, Line assist, Front assist, IC Automatic high/ low beam,
Sincerely yours
Fing32 McTallman
10-17-2017, 02:16 PM
RE: Help needed - 2010 W212 with SLA (TSA) not wotking
What country are you in?
________________________________________________________________________________​​______
10-17-2017, 02:18 PM (This post was last modified: 10-17-2017 02:22 PM by McTallman.)
(10-17-2017 02:16 PM)Rocinante Wrote:  What country are you in?
Norway.
Will giving vin and/ or datacard help?
Sincerely yours
Fing32 McTallman
10-17-2017, 07:23 PM (This post was last modified: 10-17-2017 07:30 PM by Jake5555.)
RE: Help needed - 2010 W212 with SLA (TSA) not working
No need to give VIN or datacard.
If it is original option than the correct coding for countrys needs to be done by vediamo.
If it is retrofited certain ECUs need to have the coding done.
You´ve got two possibilities:
First:
Due to my knowledge Xentry is not able to activate or deactivate the countrys.
You need to activate your country (and if you want even more countrys) by vediamo inside your camera. Did it with my own camera with sign recogniction.
The cam does recognize even the end of speed limit signs.
And speedlimit signs which are for rainydays.
If you got the correct firmware in IC, cgw and comand it will even show the recognized signs in the comand display together with IC.
Second:
possibility is to buy a module at ebay.
You need just to search for SLA.
But in my opinion too expensive for a option which is possible to be activated by software.
BR
Jake
Attached File(s) Thumbnail(s)
 Thanks given by: Rocinante , McTallman , temo4ka
10-18-2017, 01:08 AM
Mercedes Benz RE: Help needed - 2010 W212 with SLA (TSA) not working
(10-17-2017 07:23 PM)Jake5555 Wrote:  No need to give VIN or datacard.
First:
Second:
BR
Jake
Thank you for the reply. It then seems like the problem is in the camera, since the car is original fitted with this option and is works outside my country.
I have Vediamo on one of my computers, but have never tested or used it. Maybe I can get your Vediamo guide and start to learn how to use it?
(also have AVDI, but doubt this can do it, or?)
Sincerely yours
Fing32 McTallman
10-18-2017, 01:17 AM
It´s not really a problem to change it.
But you need to figure out how to use vediamo.
I am not familar with Avdi, so I can´t tell you if it possible with this tool.
About the faq please send me a PM.
 Thanks given by: McTallman
11-07-2017, 11:47 PM
What unit to look for to find camera i Vediamo? Find it as MFK in Xentry, but can not find it in Vediamo...
Sincerely yours
Fing32 McTallman
11-08-2017, 01:36 AM
First:
Second:
BR
Jake
U cant activate 513 code by software, u need 513 inside MFK, also camera requires calibration after coding
11-08-2017, 01:55 AM (This post was last modified: 11-08-2017 04:46 AM by Jake5555.)
First:
Second:
BR
Jake
yes just when you want to retrofit.,
This is something different!!!!
He has this option originally. like i have!!!
SO nothing is build in (NO RETROFIT)!
If cam was calibrated before no need of calibration after coding the countries!!!
@tirex2k
Don´t lead him in the wrong direction.
  w212 audio50>comand ntg 4.0 retrofit Onotole 3 535 Yesterday 07:59 PM
Last Post: sherwin1111
Mercedes Benz Need DAS whit w204, w212... Turbodream 15 7,893 Yesterday 05:50 AM
Last Post: rukako
Mercedes Benz W212 airbag problem Moodyali80 1 211 04-17-2018 12:02 PM
Last Post: shmuk
  W212 can bus off fault scaniamastertech 19 2,077 04-15-2018 03:09 AM
Last Post: A2ua
Mercedes Benz w212 blind spot removing issue kuba5582 4 406 04-14-2018 04:54 PM
Last Post: rashid
