Help needed renolink software clio 3 possible uch issue
11-14-2017, 08:38 AM (This post was last modified: 11-14-2017 08:40 AM by norman1967.)
Hello lads
Need a little bit of help here if we have any Renault experts.
So Customer of mine had a 2006 clio 3 immobiler light on No start. I go out to it and scan I get fault code. Df048 = protection code between uch and eps.
So I researched software to sync again and I found this for sale
http://mhhauto.com/Thread-RENOLINK-Softw...t=Renolink
So I buy it and go to job. I managed to renew eps and I also renew uch I also clicked to make virgin uch 1087
Now immobiler light is out and fault is gone. But still no crank.
I asked seller he suggest I recode uch but he has no experience either so cannot advice me on how to do so.
So I have no longer the origoanl fault code. Only codes I see now relate to throttle body. They will not clear. Red immobiler light is out and stays out
And I need help. Beer
11-14-2017, 08:49 AM
RE: Help needed renolink software clio 3 possible uch issue
Df048 is error for power steering ... you must to fix or to change it after to programing
 Thanks given by: norman1967
11-14-2017, 08:52 AM
Cheers for reply. Df048 fault has gone now. Immobiler light no longer flashing
11-14-2017, 09:02 AM (This post was last modified: 11-14-2017 09:05 AM by autoro.)
soo ..if u have not tool like renault ecu tool u must to find proper file for 24c16 ,, obviously sellers have not time for repair .. and in this field world is divide by developer , seller or re-seller and final user
11-14-2017, 09:03 AM (This post was last modified: 11-14-2017 09:05 AM by norman1967.)
(11-14-2017 09:02 AM)autoro Wrote:  soo ..if u have not tool like renault ecu tool u must to find proper file for 24c16
Your speaking about 24c16 inside uch?
If yes. I can read epprom no problem but populate it with ?
Who can rebuild file..?
11-14-2017, 09:10 AM
df048.txt
File Type: .txt
Downloaded: 4 times
our father google
11-14-2017, 09:20 AM
Fault code df048 is resolved. Fault has gone. Car still not start. I made error and made uch virgin not eps
11-14-2017, 09:22 AM (This post was last modified: 11-14-2017 09:23 AM by autoro.)
learn uch and after solve eps
11-14-2017, 09:37 AM
(11-14-2017 09:22 AM)autoro Wrote:  learn uch and after solve eps
Can you please write steps on how to learn uch and tools needed?
Maybe somebody know immobiler off solution?
  Help needed renolink software clio 3 possible uch issue norman1967 2 285 11-14-2017 11:33 PM
Last Post: norman1967
  Laguna II UCH dump repair mondek2000 0 412 10-04-2017 03:54 AM
Last Post: mondek2000
  Renault trafic 2015 T4 UCH Module Flash nogger 0 149 09-26-2017 06:58 AM
Last Post: nogger
  Dump uch clio3 chaoui05 2 115 09-22-2017 08:26 PM
Last Post: chaoui05
Renult Derelek DDT2000 issue dunkler 2 232 09-20-2017 06:55 AM
Last Post: dunkler
  Primastar UCH-N3 pinout/wiring nogger 1 141 09-19-2017 11:14 AM
Last Post: Synkrotronic
  UCH - N2 pin help needed shifty1976 2 262 02-26-2017 08:42 AM
Last Post: fishingman
Nissan N13 Pulsar Injection Issue Perry 0 238 01-06-2017 07:23 PM
Last Post: Perry
Dacia RenolinK-function Ocs ovy85 2 1,019 12-22-2016 06:04 AM
Last Post: ovy85
Renult Renault Traffic UCH ESP fault Misterwit123 2 691 06-30-2016 08:35 AM
Last Post: Misterwit123
