  • 22 Votes - 2.86 Average
Helps to read by BDM with galleto2 (siemens simos ppd 1.2)
02-07-2013, 02:02 AM (This post was last modified: 02-07-2013 02:10 AM by javiercj.)
VW Helps to read by BDM with galleto2 (siemens simos ppd 1.2)
Hello friends.
I have a problem.
I'm starting with the galleto 2. And although I last had more or less complete to read by bdm documentation
attachment the photo ecu
had this ECU, but had doubts to read by BDM with GALLETO2
Siemens Simos PPD 1.2 (vw passat year 2008))
it have several doubts, with the documentation that appears.
-only appears the UNIT ecu SIEMENS PPD 1.1
the pin-out is the same as the PPD 1.2?
- two adapters siemens appear, but does not identify which use. And apparently they are both the same adapters but change the jumpers.
You have documentation more accurate (most complete) for the galleto2 and go safe to read the ECU by BDM.?
tHE adapters ARE used BY soldiers or by cables.?
can YOU HELP ME
THANKS
Attached File(s)
uce vw pssat 2008.rar
File Type: .rar
Downloaded: 206 times
 Thanks given by: willyboy
02-07-2013, 05:15 AM
RE: Helps to read by BDM with galleto2 (siemens simos ppd 1.2)
Find the ground and go.
 Thanks given by: javiercj , mula
02-07-2013, 10:28 PM
(02-07-2013 05:15 AM)Neron-ek Wrote:  Find the ground and go.
Thank you.
But that image which is the mass (gnd) of the uce, does not correspond with the siemens PPD 1.1
and also the question which use 2 adapters of siemens
thank you
02-08-2013, 03:14 AM
You can principle use both adapters..
the difference between the two is that they are to 180° rotated..
02-08-2013, 06:35 AM
(02-08-2013 03:14 AM)Chip-Tuning Wrote:  You can principle use both adapters..
the difference between the two is not correct.
the jumper in between is diferent and type are different.
thanks
12-24-2013, 11:00 PM
Does someone has bdm pin out of Siemens PPD 1.2?
I have two adapters for Siemens ECUs, but they are different and I don't know which to use.
  skoda octavia 1,6 petrol simos immo off rktech 3 134 Yesterday 03:55 AM
Last Post: Adrian_b
Skoda immo off simos 3pg 7002 intesa.x 2 84 07-20-2017 03:24 PM
Last Post: intesa.x
VW Simos 3.4A Passat 1.6 P0420 dtc epromcars 3 100 07-19-2017 11:35 PM
Last Post: MK2-VRT
Rover vag siemens ppd 1.2G dpf off gogost 2 135 07-19-2017 12:14 AM
Last Post: MK2-VRT
  vag siemens ppd 1.2 dpf off chora 3 259 07-18-2017 09:49 AM
Last Post: gogost
  Fabia 1.4 93c76 immoOFF SIMOS 3PB 047906033J seba100377 1 98 07-15-2017 07:38 AM
Last Post: strruja
  Skoda Fabia Immo Off Simos 9.1 adranbu 5 177 07-14-2017 04:18 AM
Last Post: adranbu
  IMMO OFF for Polo 9N 1.2 93C76 Simos Tabaluga 2 173 07-06-2017 07:00 AM
Last Post: Tabaluga
VW faulty ecu passat simens simos ppd1.5 ayoubcredit 0 137 07-03-2017 01:17 PM
Last Post: ayoubcredit
VW dpf off on ECU VW golf 5 siemens simos PPD1.2 habbou 6 194 06-27-2017 01:58 PM
Last Post: edgaras
