  • 160 Votes - 2.71 Average
Honda HDS V.3.002.032+CMU
08-02-2012, 02:58 PM (This post was last modified: 08-02-2012 11:39 PM by Patrian.)
Here is HDS V 3002032 +CMU it is working good with and only SPX MVCI but there is no IMMO button, looks like the latest one with Immo was 2.027. Maybe I'm wrong ?
Edit By Admin Patrian
Pssssssssssssssssst:
Please read the MHH Rules! Kolo
MHH Rules (Click Me Damn it!) Headbang
Rule #7
Attached File(s)
Link.txt
File Type: .txt
Downloaded: 807 times
 Thanks given by: Daredevil , Patrian , svid , simon1414 , gabriell , 1955roman , klairc , paro44 , asep0078 , NutsBoltsElectrons , josebruno , pitu , siriuslee , mdanilo , boy_n , Zag , antonypaul , smokky , vinnycaz , cmcw828 , voevoda_alex , duyleauto , irshad2k , gordi415 , Abclockinc , penseur , iosha789 , counder2000 , franck106 , mabuhamdy , engel555 , hargsv , Forward01 , meganegro , Vinyo , ThuanCKD , Simmerring
08-06-2012, 07:13 PM
RE: Honda HDS V.3.002.032+CMU
is there a way to get the immo function on ? i use hds gna600 with the dealer code(crack).i have immo function.im going to update to mvci.but if immo function is disabled for after maerket.no good ,any thouhts about it?
08-07-2012, 03:45 AM
Honda RE: Honda HDS V.3.002.032+CMU
(08-06-2012 07:13 PM)klairc Wrote:  is there a way to get the immo function on ? i use hds gna600 with the dealer code(crack).i have immo function.im going to update to mvci.but if immo function is disabled for after maerket.no good ,any thouhts about it?
Are you talking about the SPX MVCI Sir, oir about the XHorse Interfaces 1st of all????? 533
Because ANY Version 3.xxx.xxx supporting ONLY the SPX MVCI! Listen
Best Regards! Cheer2
Remember: The chances they ARE BIG, when we LOOSING them... Listen
 Thanks given by: pitu
08-28-2012, 05:57 AM
Is this Hds v. 3 multilanguage?
Can It work with HIM clone?
THX
08-28-2012, 06:50 AM
(08-28-2012 05:57 AM)franz727272 Wrote:  Is this Hds v. 3 multilanguage?
THX
1st of all put your glasses in your "Eyes" and read WHAT i saying in my Post! Fing20
2nd, HDS for Europe or for General Region = Nod Multilanguage! Listen
AP
 Thanks given by: Daredevil , bigdiez , franz727272
08-28-2012, 12:20 PM
THX
AP
Have have this version running using ALLscanner there is Immo function. If you use USA to install not immo function. I have use Japan and General to set up all have immo function.
 Thanks given by: TizWaz
08-29-2012, 06:16 AM (This post was last modified: 08-29-2012 07:15 AM by Patrian.)
(08-28-2012 12:20 PM)topend Wrote:  Have have this version running using ALLscanner there is Immo function. If you use USA to install not immo function. I have use Japan and General to set up all have immo function.
What number you used to set up to Japan and General ?
08-29-2012, 10:17 AM (This post was last modified: 08-29-2012 11:21 AM by Patrian.)
(08-29-2012 06:16 AM)Klmauto Wrote:  What number you used to set up to Japan and General ?
Japan requires number format 7 numbers a dash then 2 numbers
so I tryed 1234567-89 and it installed just fine.
Same for General it tell you what the number format is I just used a number starting with 1234.....
It worked on all the version I have installed so far.
Just a note
When I downloaded this software it comes with a SPX folder. I removed this folder before installing as this installs the drivers etc for the SPX device which I do not have.
 Thanks given by: Klmauto
10-13-2012, 04:53 AM
Just a note
Hi topend
please can you share the link for allscanner hds driver and guide for hds ver 3.0 , how did you manage it to run using allscanner vcx driver ?
regards
sraj
 Thanks given by: penseur
  Honda HDS i-HDS J2534 Rewrite 6.10.17 spkmal2 15 3,042 08-15-2017 06:16 AM
Last Post: chan ts
Honda HONDA HDS 3.012.030 TizWaz FULL Build TizWaz 211 99,214 08-06-2017 11:04 AM
Last Post: carol1869
  Link Honda HDS V3.101.015 jaime20 6 424 07-21-2017 05:39 PM
Last Post: jaime20
  Mongoose - HDS Honda Original jaime20 5 684 07-21-2017 05:14 PM
Last Post: jaime20
BMW BMW ISTA/P 3.61.4.002 [05.2017] Multilingual megashared 0 299 06-30-2017 05:13 AM
Last Post: megashared
BMW BMW ISTA/D Rheingold 4.05.31 + ISTA/SDP 4.05.22 + ISTA/P 3.61.4.002 + Tools megashared 0 611 06-30-2017 05:12 AM
Honda Honda HDS 3.101.019 Multilingual + ECU Rewrite megashared 2 1,486 06-18-2017 03:19 AM
Last Post: SC0TT
  Honda HDS 3.101.019 torrent ziomal4340 4 1,158 06-16-2017 08:10 AM
Last Post: valleng
BMW BMW Rheingold 4.05.31 Standalone / SDP 4.05.22 / ISTA-P 3.61.4.002 Tulex 0 949 05-29-2017 11:11 PM
Last Post: Tulex
Honda hds password robbie 2 392 04-23-2017 02:37 PM
Last Post: narkeleptk
